查看: 2348|回复: 3
[求助] 舵机接入ha后没有实体怎么办
发表于 2022-11-21 20:54:34 来自手机 | 显示全部楼层 |阅读模式
然后通过开发者服务这里可以控制,ha里的con.yaml文件配置具体要怎么配置怎么弄?我已经我这样子配置了但是还是没有实体
 楼主| 发表于 2022-11-21 21:10:01 | 显示全部楼层
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: "****"
  password: "****"
  ap:
    ssid: "Esp01S Duoji A Fallback Hotspot"
    password: "jDCjJVxeZQAv"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
ota:
  password: "****"
# 舵机服务
api:
  password: "****"
  services:
    - service: control_servo
      variables:
        level: float
        level_reset: float
      then:
        - servo.write:
            level: !lambda 'return level / 100.0;'
        - delay: 600ms
        - servo.write:
            level: !lambda 'return level_reset / 100.0;'
servo:
  - id: my_servo
    output: pwm_output
# 舵机控制
output:
  - platform: esp8266_pwm
    pin: D4
    frequency: 50 Hz
这是固件代码
 楼主| 发表于 2022-11-21 21:11:38 | 显示全部楼层
input_number:
  servo_control:
    initial: 0
    min: -100
    max: 100
    step: 1
    mode: slider
automation:
  - alias: Write Servo Value to ESP
    trigger:
      platform: state
      entity_id: input_number.servo_control
    action:
      - service: esphome.8266servo_control_servo
        service_data:
    level: 100
    level_reset: 0
这是ha的con.yaml配置
哪里是出现什么问题吗
发表于 2022-12-3 22:30:24 来自手机 | 显示全部楼层
顶起来,等大佬帮忙解惑
GMT+8, 2025-12-19 02:07 , Processed in 0.731389 second(s), 11 queries , MemCached On.
