查看: 3438|回复: 8
[求助] ESPHOME接入GPS模块后,HASS里如何变为device_tracker
发表于 2022-11-19 15:56:29 | 显示全部楼层 |阅读模式
请教如何将ESPHOME接入的GPS传感器,在HASS变为一个device_tracker,求救!
发表于 2022-11-19 18:05:21 | 显示全部楼层
顶一个  以后也整一个出来
发表于 2022-11-19 20:06:53 | 显示全部楼层
参考gpslogger,app的用法
 楼主| 发表于 2022-11-19 20:10:09 | 显示全部楼层
参考:
https://community.home-assistant ... -coordinates/142971
automation:
  - trigger:
      platform: state
      entity_id: sensor.kia_position_lat, sensor.kia_position_long
    action:
      service: device_tracker.see
      data_template:
        dev_id: kia
        gps:
          - "{{ states('sensor.kia_position_lat') }}"
          - "{{ states('sensor.kia_position_long') }}"
 楼主| 发表于 2022-11-19 20:20:51 | 显示全部楼层
xuyang 发表于 2022-11-19 20:06
参考gpslogger,app的用法
谢谢,我也去学习一下
 楼主| 发表于 2022-11-20 03:28:09 | 显示全部楼层
实践方法是创建一个自动化,系统会自动创建一个Device.tracker
alias: BensonCar Postion
description: ""
trigger:
  - platform: state
    entity_id:
      - sensor.bencar_latitude
      - sensor.bencar_longitude
condition: []
action:
  - service: device_tracker.see
    data_template:
      dev_id: d8cd7c38003f3c2b79a6e1fa5b1efc6b
      gps:
        - "{{ states('sensor.bencar_latitude') }}"
        - "{{ states('sensor.bencar_longitude') }}"
mode: single
发表于 2022-11-20 10:02:01 来自手机 | 显示全部楼层
device_tracker.see   调用这个服务就行
 楼主| 发表于 2022-11-20 10:59:38 | 显示全部楼层
谢谢,成功了
发表于 2022-11-20 18:37:07 | 显示全部楼层
还能这样操作,学到了,我是用mqtt json弄的
GMT+8, 2025-12-19 04:17 , Processed in 1.024530 second(s), 8 queries , MemCached On.
