查看: 2342|回复: 0
[求助] 树莓派4B docker homeassistant supervisor 安装失败
发表于 2022-11-19 14:38:44 | 显示全部楼层 |阅读模式
最近 homeassistant supervisor 升级出错只能重装,可是按照官网的要求使用Debian11和新版的Raspberry Pi OS (64-bit)安装都不成功,也没有报错,就是不安装。有没有人遇到过?
dpkg -i homeassistant-supervised.deb
(正在读取数据库 ... 系统当前共安装有 39835 个文件和目录。)
准备解压 homeassistant-supervised.deb  ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
正在忽略 通过 homeassistant-supervised 从 /etc/NetworkManager/NetworkManager.conf 到 /etc/NetworkManager/NetworkManager.conf.real 的转移
正在忽略 通过 homeassistant-supervised 从 /etc/NetworkManager/system-connections/default 到 /etc/NetworkManager/system-connections/default.real 的转移
正在忽略 通过 homeassistant-supervised 从 /etc/docker/daemon.json 到 /etc/docker/daemon.json.real 的转移
正在忽略 通过 homeassistant-supervised 从 /etc/network/interfaces 到 /etc/network/interfaces.real 的转移
正在解压 homeassistant-supervised (1.2.1) 并覆盖 (1.2.1) ...
正在设置 homeassistant-supervised (1.2.1) ...
[info] Restarting NetworkManager
[info] Restarting docker service
PING version.home-assistant.io (104.26.5.238) 56(84) bytes of data.
64 bytes from 104.26.5.238 (104.26.5.238): icmp_seq=1 ttl=54 time=162 ms
--- version.home-assistant.io ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 161.935/161.935/161.935/0.000 ms
[info] Install supervisor startup scripts
[info] Install AppArmor scripts
[info] Start Home Assistant Supervised
[info] Installing the 'ha' cli
[info] Within a few minutes you will be able to reach Home Assistant at:
[info] http://homeassistant.local:8123 or using the IP address of your
[info] machine: http://10.10.1.10:8123
GMT+8, 2025-12-19 04:14 , Processed in 0.873489 second(s), 6 queries , MemCached On.
