楼主: dscao
[插件集成] ikuai多功能集成[2024.8.27] 和 openwrt[2024.10.23]简单控制集成
发表于 2022-12-12 15:00:01 | 显示全部楼层
膜拜大佬膜拜大佬膜拜大佬膜拜大佬膜拜大佬膜拜大佬膜拜大佬
发表于 2022-12-14 20:14:59 | 显示全部楼层
购买了,但是咋用啊
3万
 楼主| 发表于 2022-12-14 20:46:03 | 显示全部楼层
ly90907 发表于 2022-12-14 20:14
购买了,但是咋用啊
先将附件解压后将custom_components中的文件夹复制到ha中对应目录中,重启ha后,强制刷新浏览器一次,进入集成,搜索: ikuai 或 openwrt,按提示配置即可。
发表于 2022-12-15 15:18:55 | 显示全部楼层
发表于 2022-12-20 11:04:25 | 显示全部楼层
dscao 发表于 2022-12-14 20:46
先将附件解压后将custom_components中的文件夹复制到ha中对应目录中,重启ha后,强制刷新浏览器一次,进 ...
感谢回复,ikuai可以用, openwrt不行。
esxi 虚拟机装的openwrt,openwrt docker装的homeassistant
正在重试设置: None
log:
2022-12-20 02:54:51.343 ERROR (MainThread) [custom_components.openwrt] Unexpected error fetching openwrt data: "name='sysauth', domain=None, path=None"
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 225, in _async_refresh
    self.data = await self._async_update_data()
  File "/config/custom_components/openwrt/__init__.py", line 123, in _async_update_data
    sysauth = await self.get_access_token()
  File "/config/custom_components/openwrt/__init__.py", line 112, in get_access_token
    self._token = await self._fetcher._login_openwrt()
  File "/config/custom_components/openwrt/data_fetcher.py", line 93, in _login_openwrt
    resdata = await self._hass.async_add_executor_job(self.requestpost_cookies, url, header, body)
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/openwrt/data_fetcher.py", line 76, in requestpost_cookies
    resdata = responsedata.cookies["sysauth"]
  File "/usr/local/lib/python3.10/site-packages/requests/cookies.py", line 334, in __getitem__
    return self._find_no_duplicates(name)
  File "/usr/local/lib/python3.10/site-packages/requests/cookies.py", line 413, in _find_no_duplicates
    raise KeyError(f"name={name!r}, domain={domain!r}, path={path!r}")
KeyError: "name='sysauth', domain=None, path=None"
3万
 楼主| 发表于 2022-12-20 11:15:16 | 显示全部楼层
看来跟前面的朋友一样,固件不同,数据返回格式不同。
发表于 2022-12-20 20:50:43 | 显示全部楼层
我的openwrt固件是官方纯净版的,理论上没有问题吧?
3万
 楼主| 发表于 2022-12-21 09:28:31 | 显示全部楼层
我用的不是官方的版本,而是 Lean 源码编译的。
发表于 2022-12-30 08:51:13 | 显示全部楼层
下载来试试呢
发表于 2023-1-7 10:36:10 | 显示全部楼层
最新版本的爱快插件用起来用起来真爽,完美。楼主辛苦了!
GMT+8, 2025-9-19 02:54 , Processed in 1.375823 second(s), 14 queries , MemCached On.
