查看: 2852|回复: 6
[求助] 删帖
发表于 2022-11-17 13:19:15 | 显示全部楼层 |阅读模式
删帖
智能家居&单板滑雪痴迷爱好者
发表于 2022-11-17 16:26:37 | 显示全部楼层
论坛技术达人。。。这问题问的有点儿不应该呀
关于这个问题的帖子有过很多,搜搜就明白了。
简单说就是vmm+hassos,不嫌折腾的话就vmm+debian+hassio。
如果还是dsm6.x,群晖docker+hassio也勉强可以
 楼主| 发表于 2022-11-17 16:46:42 | 显示全部楼层
我以为能合在一起呢 我在研究吧 我现在是esxi +dock解决的
智能家居&单板滑雪痴迷爱好者
发表于 2022-11-17 20:05:32 | 显示全部楼层
你不是说群晖么?怎么还有esxi?
 楼主| 发表于 2022-11-18 11:54:31 | 显示全部楼层
XCray 发表于 2022-11-17 20:05
你不是说群晖么?怎么还有esxi?
我在群辉用的ha 然后esxi 用的hassio 解决的 目前已经把群辉的转到esxi了 docke不方便
发表于 2022-11-18 13:46:37 | 显示全部楼层
借楼问一下,docker安装nodered,安装微信的节点没问题,正常安装,但是安装node-red-contrib-home-assistant-websocket一直报网络错误
2022-11-18T05:35:22.174Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict [email protected]
2022-11-18T05:35:23.234Z [err] npm
2022-11-18T05:35:23.235Z [err]  WARN
2022-11-18T05:35:23.236Z [err] config production Use `--omit=dev` instead.
2022-11-18T05:40:29.873Z [err] npm
2022-11-18T05:40:29.875Z [err]  ERR! code ECONNRESET
2022-11-18T05:40:29.875Z [err] npm ERR!
2022-11-18T05:40:29.875Z [err] syscall
2022-11-18T05:40:29.878Z [err]  read
2022-11-18T05:40:29.878Z [err] npm ERR! errno ECONNRESET
2022-11-18T05:40:29.883Z [err] npm ERR! network request to https://registry.npmjs.org/browser-sync failed, reason: read ECONNRESET
2022-11-18T05:40:29.883Z [err] npm ERR! network This is a problem related to network connectivity.
2022-11-18T05:40:29.885Z [err]  In most cases you are behind a proxy or have bad network settings.
2022-11-18T05:40:29.885Z [err] npm ERR! network
2022-11-18T05:40:29.885Z [err] npm ERR! network If you are behind a proxy, please make sure that the
2022-11-18T05:40:29.885Z [err] npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
2022-11-18T05:40:29.893Z [err]
2022-11-18T05:40:29.894Z [err] npm
2022-11-18T05:40:29.894Z [err] ERR! A complete log of this run can be found in:
2022-11-18T05:40:29.894Z [err] npm ERR!     /data/.npm/_logs/2022-11-18T05_35_23_107Z-debug-0.log
请问这个怎么解决
发表于 2022-11-24 21:35:41 | 显示全部楼层
docker 安装没有 add-on, 用 vmm + hassos 虚拟机搞吧。docker 一些add-on可以通过群晖docker安装,然后用各种连起来。如果内存够还是虚拟机比较方便。
GMT+8, 2025-12-16 19:54 , Processed in 1.139527 second(s), 12 queries , MemCached On.
