查看: 2184|回复: 4
[技术探讨] 树莓派系统docker安装无法启动 求高手帮助!
发表于 2022-11-17 07:54:49 | 显示全部楼层 |阅读模式
homeassistant/raspberrypi-homeassistant:2022.6.5
homeassistant/raspberrypi-homeassistant:2021.5.4
以上版本都可以正常安装启动
但是高新版本都无法启动 容器状态时正常的 但就是8123登录不进去
查看log就一直循环下面的内容
s6-rc: info: service s6rc-oneshot-runner: starting,
s6-rc: info: service s6rc-oneshot-runner successfully started,
s6-rc: info: service fix-attrs: starting,
s6-rc: info: service fix-attrs successfully started,
s6-rc: info: service legacy-cont-init: starting,
s6-rc: info: service legacy-cont-init successfully started,
s6-rc: info: service legacy-services: starting,
services-up: info: copying legacy longrun home-assistant (no readiness notification),
s6-rc: info: service legacy-services successfully started,
[22:33:26] INFO: Home Assistant Core finish process exit code 256,
[22:33:26] INFO: Home Assistant Core finish process received signal 4,
[22:33:30] INFO: Home Assistant Core finish process exit code 256,
[22:33:30] INFO: Home Assistant Core finish process received signal 4,
[22:33:35] INFO: Home Assistant Core finish process exit code 256,
[22:33:35] INFO: Home Assistant Core finish process received signal 4,
[22:33:40] INFO: Home Assistant Core finish process exit code 256,
[22:33:40] INFO: Home Assistant Core finish process received signal 4,
[22:33:45] INFO: Home Assistant Core finish process exit code 256,
[22:33:45] INFO: Home Assistant Core finish process received signal 4,
[22:33:49] INFO: Home Assistant Core finish process exit code 256,
[22:33:49] INFO: Home Assistant Core finish process received signal 4,
[22:33:54] INFO: Home Assistant Core finish process exit code 256,
[22:33:54] INFO: Home Assistant Core finish process received signal 4,
[22:34:00] INFO: Home Assistant Core finish process exit code 256,
[22:34:00] INFO: Home Assistant Core finish process received signal 4,
[22:34:04] INFO: Home Assistant Core finish process exit code 256,
[22:34:04] INFO: Home Assistant Core finish process received signal 4,
[22:34:09] INFO: Home Assistant Core finish process exit code 256,
[22:34:09] INFO: Home Assistant Core finish process received signal 4,
[22:34:13] INFO: Home Assistant Core finish process exit code 256,
[22:34:13] INFO: Home Assistant Core finish process received signal 4,
[22:34:18] INFO: Home Assistant Core finish process exit code 256,
[22:34:18] INFO: Home Assistant Core finish process received signal 4,
[22:34:23] INFO: Home Assistant Core finish process exit code 256,
[22:34:23] INFO: Home Assistant Core finish process received signal 4,
[22:34:28] INFO: Home Assistant Core finish process exit code 256,
[22:34:28] INFO: Home Assistant Core finish process received signal 4,
[22:34:33] INFO: Home Assistant Core finish process exit code 256,
[22:34:33] INFO: Home Assistant Core finish process received signal 4,
[22:34:37] INFO: Home Assistant Core finish process exit code 256,
[22:34:37] INFO: Home Assistant Core finish process received signal 4,
[22:34:42] INFO: Home Assistant Core finish process exit code 256,
[22:34:42] INFO: Home Assistant Core finish process received signal 4,
[22:34:47] INFO: Home Assistant Core finish process exit code 256,
[22:34:47] INFO: Home Assistant Core finish process received signal 4,
[22:34:52] INFO: Home Assistant Core finish process exit code 256,
[22:34:52] INFO: Home Assistant Core finish process received signal 4,
[22:34:56] INFO: Home Assistant Core finish process exit code 256,
[22:34:56] INFO: Home Assistant Core finish process received signal 4,
[22:35:01] INFO: Home Assistant Core finish process exit code 256,
[22:35:01] INFO: Home Assistant Core finish process received signal 4,
[22:35:06] INFO: Home Assistant Core finish process exit code 256,
[22:35:06] INFO: Home Assistant Core finish process received signal 4,
[22:35:10] INFO: Home Assistant Core finish process exit code 256,
[22:35:10] INFO: Home Assistant Core finish process received signal 4,
[22:35:15] INFO: Home Assistant Core finish process exit code 256,
[22:35:15] INFO: Home Assistant Core finish process received signal 4,
 楼主| 发表于 2022-11-17 14:55:50 | 显示全部楼层
没有人吗
发表于 2022-11-17 15:01:27 | 显示全部楼层
docker都装好了 装个面板看看更为清楚
 楼主| 发表于 2022-11-17 17:03:14 | 显示全部楼层
网页捕获_17-11-2022_17042_192.168.50.62.jpeg 网页捕获_17-11-2022_17228_192.168.50.62.jpeg
面板装了 那个log就是面看看到的
发表于 2022-11-17 19:02:20 | 显示全部楼层
很多人在讨论 2022.7和2022.9版本都有类似问题
参考:https://github.com/home-assistant/core/issues/74707
我自己Home Assistant 2022.10.3版本没任何问题,树莓派docker安装。
GMT+8, 2026-1-18 02:02 , Processed in 0.054270 second(s), 14 queries , MemCached On.
