查看: 2640|回复: 4
[求助] HA22.11版老sonoff开关switch调用MQTT怎么修改
发表于 2022-11-15 19:21:26 | 显示全部楼层 |阅读模式
早期使用了Sonoff开关调用了MQTT,现在写法要求更新,我原来的写法如下,请教大神如何修改可以在新版HA中使用(多个switch开关),谢谢!
configuration.yaml内容如下:
switch:
  - platform: mqtt
    state_topic: "stat/S1/POWER"
    command_topic: "cmnd/S1/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
  - platform: mqtt
homeassistant新文档要求按以下格式,不知道具体怎么改,麻烦大神帮改下代码。感谢
https://www.home-assistant.io/integrations/switch.mqtt/#new_format
# Example configuration.yaml entry
mqtt:
  switch:
    - command_topic: "home/bedroom/switch1/set"
改了下这样不知道有没错,怕把HA给整奔溃了,确认下(S1、S2是topic)
mqtt:
  switch:
    - unique_id: S1
      state_topic: "home/bedroom/S1"
      command_topic: "home/bedroom/S1/set"
      availability:
        - topic: "home/bedroom/S1/available"
      payload_on: "ON"
      payload_off: "OFF"
      state_on: "ON"
      state_off: "OFF"
      optimistic: false
      qos: 0
      retain: true
    - unique_id: S2
      state_topic: "home/bedroom/S2"
      command_topic: "home/bedroom/S2/set"
      availability:
        - topic: "home/bedroom/S2/available"
      payload_on: "ON"
      payload_off: "OFF"
      state_on: "ON"
      state_off: "OFF"
      optimistic: false
      qos: 0
      retain: true
参与人数 1金钱 +8 收起 理由
sorrypqa + 8 大神666!
发表于 2022-11-15 20:23:22 | 显示全部楼层
这样是对的。
我不生产技术,我只是技术的搬运工。
 楼主| 发表于 2022-11-16 11:34:01 | 显示全部楼层
似乎还是不行,能帮忙看看哪里出错吗?我修改了configuration.yaml文件后重启,没发现这些sonoff设备,日志也没有提示
sonoff固件里面topic设置为C1,以下代码是否应该把home/bedroom/这个删掉
mqtt:
  switch:
    - unique_id: S1
      availability:
      payload_on: "ON"
      payload_off: "OFF"
      state_on: "ON"
      state_off: "OFF"
      optimistic: false
      qos: 0
      retain: true
发表于 2022-11-16 14:04:02 | 显示全部楼层
mqtt:
  switch:
    - name: "Sonoff_1"
      qos: 1
      payload_on: "ON"
      payload_off: "OFF"
      retain: true
    - name: "Sonoff_2"
我不生产技术,我只是技术的搬运工。
 楼主| 发表于 2022-11-16 16:41:34 | 显示全部楼层
可以了,非常感谢,谢谢
GMT+8, 2025-12-16 02:07 , Processed in 1.102037 second(s), 8 queries , MemCached On.
