楼主: trz0332
[插件集成] 咸鱼捡垃圾(其二)wifi插座-官方插件已支持,此帖删
发表于 2023-5-6 14:20:37 | 显示全部楼层
Logger: homeassistant.loader
Source: custom_components/mobilel6/__init__.py:11
Integration: mobilel6
First occurred: 11:25:31 (6 occurrences)
Last logged: 12:04:07
Unexpected exception importing component custom_components.mobilel6
Unexpected exception importing platform custom_components.mobilel6.config_flow
  File "/usr/src/homeassistant/homeassistant/loader.py", line 813, in get_component
    ComponentProtocol, importlib.import_module(self.pkg_path)
  File "/usr/local/lib/python3.10/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 883, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/config/custom_components/mobilel6/__init__.py", line 11, in <module>
    from .device import BroadlinkDevice
  File "/config/custom_components/mobilel6/device.py", line 130
                    await self.hass.config_entries.async_forward_entry_setups(
TabError: inconsistent use of tabs and spaces in indentation
lwh201314 发表于 2023-5-5 16:51
可以,改了有用!
改了,还是出现以下错误,不能用
发表于 2023-5-6 14:34:18 | 显示全部楼层
看看看看
发表于 2023-5-6 17:38:07 | 显示全部楼层
可以,改了有用!
是不是改的那行前面的空格你用tab代替了
发表于 2023-5-6 18:12:08 | 显示全部楼层
看起来不错,你淘淘看
发表于 2023-5-8 23:20:21 | 显示全部楼层
我查看了,是用的空格,还是无效
发表于 2023-5-9 09:48:54 | 显示全部楼层
好东西 先顶 再看
发表于 2023-5-9 16:14:15 | 显示全部楼层
bg6cq 发表于 2023-3-22 23:44
这个插件来自https://github.com/home-assistan ... omponents/broadlink
参照上面的代码,我做了如下修 ...
亲测有效,大佬牛批
发表于 2023-5-11 19:53:00 | 显示全部楼层
刚好找就更新了。谢谢!
海鲜市场:jasona3
发表于 2023-5-14 15:56:39 | 显示全部楼层
系统谨慎升级哈,我刚刚升级Home Assistant 2023.5.2
前端版本: 20230503.3 - latest  ,然后全部挂了了 ,7个 都用不了,删除添加一样了
发表于 2023-5-14 16:12:01 | 显示全部楼层
前端版本: 20230503.3 - latest  ,然后全部挂了了  ...
装了新版的可以了。
GMT+8, 2026-2-5 04:00 , Processed in 0.084950 second(s), 11 queries , MemCached On.
