楼主: lidicn
从零开始【树莓派stretch】安装【docker】【hassio】【debian9】
教程狂人论坛风云人物突出贡献
 楼主| 发表于 2017-12-1 09:54:42 | 显示全部楼层
han_diannao_mi 发表于 2017-12-1 09:10
13、打开浏览器中输入树莓派IP地址:http://ip:8123,打开左侧面板的hassio界面中,添加以下地址
https://gi ...
看这个log
发表于 2017-12-1 16:02:50 来自手机 | 显示全部楼层
把教程拓展到安装mqtt吧!
发表于 2017-12-1 23:42:07 | 显示全部楼层
这个界面选择。Local      Remote 那个呢???
发表于 2017-12-1 23:49:21 | 显示全部楼层
提示这个正常吗???
发表于 2017-12-2 00:13:29 | 显示全部楼层
starting version 3.2.2
17-12-01 15:50:56 INFO (MainThread) [__main__] Initialize Hassio setup
17-12-01 15:50:56 INFO (MainThread) [hassio.bootstrap] Create Home-Assistant config folder /data/homeassistant
17-12-01 15:50:56 INFO (MainThread) [hassio.bootstrap] Create hassio ssl folder /data/ssl
17-12-01 15:50:56 INFO (MainThread) [hassio.bootstrap] Create hassio addon data folder /data/addons/data
17-12-01 15:50:56 INFO (MainThread) [hassio.bootstrap] Create hassio addon local repository folder /data/addons/local
17-12-01 15:50:56 INFO (MainThread) [hassio.bootstrap] Create hassio addon git repositories folder /data/addons/git
17-12-01 15:50:56 INFO (MainThread) [hassio.bootstrap] Create hassio temp folder /data/tmp
17-12-01 15:50:56 INFO (MainThread) [hassio.bootstrap] Create hassio backup folder /data/backup
17-12-01 15:50:56 INFO (MainThread) [hassio.bootstrap] Create hassio share folder /data/share
17-12-01 15:50:56 INFO (MainThread) [hassio.dock.network] Can't find HassIO network, create new network
17-12-01 15:50:56 INFO (MainThread) [__main__] Setup HassIO
17-12-01 15:50:56 INFO (SyncWorker_0) [hassio.dock.supervisor] Attach to supervisor homeassistant/armhf-hassio-supervisor with version 0.75
17-12-01 15:51:02 INFO (MainThread) [hassio.host_control] Send 'info' to HostControl.
17-12-01 15:51:04 INFO (MainThread) [hassio.host_control] Receive from HostControl: { "type": "generic", "version": "0.3", "last_version": "0.3", "hostname": "raspberrypi", "features": ["shutdown", "reboot", "update"], "os": "GNU/Linux" }.
17-12-01 15:51:04 INFO (MainThread) [hassio.homeassistant] No HomeAssistant docker homeassistant/raspberrypi3-homeassistant found.
17-12-01 15:51:04 INFO (MainThread) [hassio.homeassistant] Setup HomeAssistant landingpage
17-12-01 15:51:04 INFO (SyncWorker_2) [hassio.dock.interface] Pull image homeassistant/raspberrypi3-homeassistant tag landingpage.
17-12-01 15:51:09 INFO (SyncWorker_2) [hassio.dock.interface] Tag image homeassistant/raspberrypi3-homeassistant with version landingpage as latest
17-12-01 15:51:11 INFO (SyncWorker_1) [hassio.dock.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version landingpage
17-12-01 15:51:11 INFO (MainThread) [hassio.addons.git] Clone addon https://github.com/home-assistant/hassio-addons repository
17-12-01 15:52:14 ERROR (MainThread) [hassio.addons.git] Can't clone https://github.com/home-assistant/hassio-addons repo: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --recursive -v https://github.com/home-assistant/hassio-addons /data/addons/core
  stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/hassio-addons/': LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to github.com:443
17-12-01 15:52:14 ERROR (MainThread) [hassio.addons] Can't load from repository core
17-12-01 15:52:14 INFO (MainThread) [hassio.addons] Load addons: 0 all - 0 new - 0 remove
17-12-01 15:52:14 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons
17-12-01 15:52:14 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
17-12-01 15:52:14 INFO (MainThread) [__main__] Run HassIO
17-12-01 15:52:14 INFO (MainThread) [hassio.dns] Start DNS port forwarding for host add-ons
17-12-01 15:52:14 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.co ... master/version.json
17-12-01 15:52:15 INFO (MainThread) [hassio.core] Start hassio api on 172.30.32.2
17-12-01 15:52:15 INFO (MainThread) [hassio.addons] Startup system run 0 addons
17-12-01 15:52:15 INFO (MainThread) [hassio.addons] Startup services run 0 addons
17-12-01 15:52:15 INFO (MainThread) [hassio.addons] Startup application run 0 addons
17-12-01 15:52:15 INFO (MainThread) [hassio.homeassistant] Setup HomeAssistant
17-12-01 15:52:15 INFO (SyncWorker_2) [hassio.dock.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.58.1.
17-12-01 15:52:29 ERROR (SyncWorker_2) [hassio.dock.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.58.1 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:0.58.1: No such image: homeassistant/raspberrypi3-homeassistant:0.58.1").
17-12-01 15:52:29 WARNING (MainThread) [hassio.homeassistant] Error on install HomeAssistant. Retry in 60sec
17-12-01 15:53:30 INFO (SyncWorker_9) [hassio.dock.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.58.1.
17-12-01 16:07:12 INFO (SyncWorker_9) [hassio.dock.interface] Tag image homeassistant/raspberrypi3-homeassistant with version 0.58.1 as latest
17-12-01 16:07:12 INFO (MainThread) [hassio.homeassistant] HomeAssistant docker now installed
17-12-01 16:07:13 INFO (SyncWorker_18) [hassio.dock.interface] Stop homeassistant/raspberrypi3-homeassistant docker application
17-12-01 16:07:13 INFO (SyncWorker_18) [hassio.dock.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
17-12-01 16:07:17 INFO (SyncWorker_18) [hassio.dock.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.58.1
17-12-01 16:07:17 INFO (SyncWorker_2) [hassio.dock.interface] Cleanup docker images: ['homeassistant/raspberrypi3-homeassistant:landingpage']
17-12-01 16:08:38 INFO (MainThread) [hassio.addons] Load addons: 0 all - 0 new - 0 remove
17-12-01 16:08:58 INFO (MainThread) [hassio.addons.git] Clone addon https://github.com/zoranke/addon-homebridge repository
17-12-01 16:10:02 ERROR (MainThread) [hassio.addons.git] Can't clone https://github.com/zoranke/addon-homebridge repo: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --recursive -v https://github.com/zoranke/addon-homebridge /data/addons/git/e0e007d2
  stderr: 'Cloning into '/data/addons/git/e0e007d2'...
fatal: unable to access 'https://github.com/zoranke/addon-homebridge/': LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to github.com:443
17-12-01 16:10:02 ERROR (MainThread) [hassio.addons] Can't load from repository https://github.com/zoranke/addon-homebridge
17-12-01 16:10:02 INFO (MainThread) [hassio.addons] Load addons: 0 all - 0 new - 0 remove
发表于 2017-12-2 00:57:59 | 显示全部楼层
homebridge,原因是连接不到github。但是我电脑可以。Goole Youtube 都可以;
SSH ping 不通 Github。 怎么解决这个问题呢。
发表于 2017-12-2 06:20:19 来自手机 | 显示全部楼层
大神,问下,docker是什么,跟我直接安装hadsio有啥区别
发表于 2017-12-2 07:44:19 来自手机 | 显示全部楼层
好教程。学习了
教程狂人论坛风云人物突出贡献
 楼主| 发表于 2017-12-2 09:28:17 | 显示全部楼层
SSH ping 不通 Github。 怎么 ...
怎么解决的?提供一下吧
发表于 2017-12-2 11:44:27 | 显示全部楼层
lidicn 发表于 2017-12-2 09:28
怎么解决的?提供一下吧
解决了 树莓派 ping 的问题,但在图形界面还是不能安装这个插件
GMT+8, 2025-11-29 03:14 , Processed in 0.111090 second(s), 12 queries , MemCached On.
