查看: 2993|回复: 2
[基础教程] 带esp01s 的dht11模块 编译时出错
发表于 2022-11-12 20:01:42 | 显示全部楼层 |阅读模式
按照向导生成代码后
教程说把 下面的代码加入到最后
添加dht11代码
点击test工程下EDIT编程yaml文件,在结尾处添加如下代码:
#Example configuration entrysensor:
- platform: dht
    pin: GPIO2
    temperature:
      name: "Room Temperature"
    humidity:
      name: "Room Humidity"
        update_interval: 60s
        model: DHT11
我加入后这样:
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "2QomEtRj53ndOSXQnR9Pxx1HbRpEIjC7+77i2jrPkbk="
ota:
  password: "5e773360b6b335090d5cc80a7ce1faef"
wifi:
  ssid: tyunet
  password: uo98809880
  ap:
    ssid: "Test Fallback Hotspot"
    password: "ehDaBCMi8SUB"
captive_portal:
entrysensor:
- platform: dht
    pin: GPIO2
    temperature:
    humidity:
        model: DHT11
save 后 install
出错:
INFO Reading configuration /config/esphome/test.yaml...ERROR Error while reading config: Invalid YAML syntax:mapping values are not allowed here  in "/config/esphome/test.yaml", line 36, column 8:        pin: GPIO2            ^
请问大神们怎么解决?
我只是想要家里增加个温湿度检测
发表于 2022-11-13 00:02:58 | 显示全部楼层
缩进的问题
发表于 2022-11-13 10:20:48 | 显示全部楼层
试试tasmota,你会发现新的大门。
https://tasmota.github.io/docs/DHT11/
esp01+dht11只能开发用,实际使用的时候dht11温度会收到esp01的发热影响,温度会高出5-10度,另dht11的温湿度不精确,在极端情况下会发飘。如果非要使用dht11那建议用杜邦线分离dht11和esp01
GMT+8, 2025-12-27 11:45 , Processed in 1.510213 second(s), 13 queries , MemCached On.
