查看: 5797|回复: 10
[技术探讨] 求助,小米多模网关2怎么接入homeassistant,大佬求教
发表于 2022-11-6 09:36:27 | 显示全部楼层 |阅读模式
刚买的小米智能多模网关2在homeassistant设备一直不能使用,已经安装了最新的xiaomigateway3了
 楼主| 发表于 2022-11-6 15:08:30 | 显示全部楼层
有人吗,告诉一下帮帮忙接进homessistant
发表于 2022-11-6 21:02:23 来自手机 | 显示全部楼层
我也想知道,,我接入后只有网关的3个实体,其他蓝牙设备一个没有
 楼主| 发表于 2022-11-6 21:27:05 | 显示全部楼层
我这边接入实体都没有
 楼主| 发表于 2022-11-6 21:38:31 | 显示全部楼层
zml92588 发表于 2022-11-6 21:27
我这边接入实体都没有
此错误来自自定义集成。
Logger: custom_components.xiaomi_gateway3.core.gateway
Source: custom_components/xiaomi_gateway3/core/shell/shell_arm.py:17
Integration: Xiaomi Gateway 3 (documentation, issues)
First occurred: 21:36:34 (1 occurrences)
Last logged: 21:36:34
192.168.13.126 | Can't prepare gateway
  File "/usr/local/lib/python3.10/asyncio/streams.py", line 617, in readuntil
    await self._wait_for_data('readuntil')
  File "/usr/local/lib/python3.10/asyncio/streams.py", line 502, in _wait_for_data
    await self._waiter
asyncio.exceptions.CancelledError
  File "/usr/local/lib/python3.10/asyncio/tasks.py", line 456, in wait_for
    return fut.result()
The above exception was the direct cause of the following exception:
  File "/config/custom_components/xiaomi_gateway3/core/gateway/__init__.py", line 174, in prepare_gateway
    async with shell.Session(self.host) as sh:
  File "/config/custom_components/xiaomi_gateway3/core/shell/__init__.py", line 29, in __aenter__
    return await self.login()
  File "/config/custom_components/xiaomi_gateway3/core/shell/__init__.py", line 54, in login
    await shell.login()
  File "/config/custom_components/xiaomi_gateway3/core/shell/shell_arm.py", line 17, in login
    await asyncio.wait_for(coro, timeout=3)
  File "/usr/local/lib/python3.10/asyncio/tasks.py", line 458, in wait_for
    raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
谁能帮看看什么问题
发表于 2022-11-6 22:01:36 | 显示全部楼层
直接删除集成重新下载master版本就行了,蓝牙zigbee都可以接入的
发表于 2022-11-7 09:55:34 | 显示全部楼层
[img]网关设为静态ip,免得重启变ip。
{"method":"set_ip_info","params":{"ssid":"\"\"","pswd":"123123 ; passwd -d root ; echo enable > /sys/class/tty/tty/enable; telnetd"}}
打开telnet的命令填上面的这一串
自动下载最新的gateway3插件仅支持zigbee,作者下次更新时才会打包进去,要提前用蓝牙和mesh需要使用手动安装的方式,下载GitHub里的文件自己覆盖安装[/img]
发表于 2022-11-7 13:27:42 | 显示全部楼层
我这边接入实体都没有
我的其实已经正常接入了,只是设备要重新接入米家才会在多模2里出现,真是坑人啊。你可能是没安装对,看7楼方法
发表于 2022-11-7 14:17:52 | 显示全部楼层
如果之前用多模1接入的,需要先删除多模1这个,再添加多模2
发表于 2023-1-9 11:34:06 | 显示全部楼层
目前我也安装了master版本,网关里也只有1个设备3个实体,蓝牙子设备没有显示,网上找了2个telnet尝试也没有用,郁闷
GMT+8, 2026-1-17 19:42 , Processed in 1.306008 second(s), 13 queries , MemCached On.
