查看: 1884|回复: 3
[求助] node-red13.5.1崩溃,运行不起
发表于 2022-11-5 23:31:56 | 显示全部楼层 |阅读模式
[color=var(--primary-text-color)]Home Assistant 2022.11.1Supervisor 2022.10.2Operating System 9.3前端版本: 20221102.1 - latest
[23:25:58] INFO: [color=var(--success-color)]Starting NGinx...5 Nov 23:25:58 - [red] Uncaught Exception:5 Nov 23:25:58 - [error] TypeError: RED.settings.functionGlobalContext.get is not a function    at map (/config/node-red/node_modules/node-red-contrib-actionflows/actionflows/actionflows.js:270:51)    at EventEmitter.runtimeMap (/config/node-red/node_modules/node-red-contrib-actionflows/actionflows/actionflows.js:593:5)    at EventEmitter.emit (node:events:513:28)    at Object.start [as startFlows] (/opt/node_modules/@node-red/runtime/lib/flows/index.js:405:12)[23:25:59] WARNING: [color=var(--warning-color)]Node-RED crashed, halting add-on[23:25:59] INFO: [color=var(--success-color)]Node-RED stopped, restarting...s6-rc: info: service legacy-services: stopping[23:25:59] INFO: [color=var(--success-color)]Node-RED stopped, restarting...s6-svwait: fatal: supervisor dieds6-rc: info: service legacy-services successfully stoppeds6-rc: info: service legacy-cont-init: stoppings6-rc: info: service legacy-cont-init successfully stoppeds6-rc: info: service fix-attrs: stoppings6-rc: info: service fix-attrs successfully stoppeds6-rc: info: service s6rc-oneshot-runner: stopping[23:25:59] INFO: [color=var(--success-color)]nginx stopped, restarting...s6-rc: info: service s6rc-oneshot-runner successfully stopped
hyq
发表于 2022-11-6 09:04:41 | 显示全部楼层
没有吧!我的运行正常呀!重启大法!
 楼主| 发表于 2022-11-6 09:07:48 | 显示全部楼层
hyq 发表于 2022-11-6 09:04
没有吧!我的运行正常呀!重启大法!
不行。。。。。
hyq
发表于 2022-11-6 09:11:32 | 显示全部楼层
我好像也是刚更新的时候崩了!后来断电抽了一根烟再重启就可以了!
GMT+8, 2025-11-5 14:00 , Processed in 0.367203 second(s), 5 queries , MemCached On.
