查看: 4528|回复: 14
[求助] 这种易微联模块可以接入homeassistant并实现局域网控制吗?
Emin 手机认证
发表于 2022-10-31 15:21:49 | 显示全部楼层 |阅读模式
设备如图,在易微联app设备专属页面中没有打开局域网控制选项,Homeassistant的系统信息中,显示
Local devices online0 / 0
,恳请大佬答疑解惑。
Emin 手机认证
 楼主| 发表于 2022-10-31 17:06:55 | 显示全部楼层
论坛没有兄弟使用过啊,选了很久选了这个产品,听说易微联可以局域网控制   结果好像不行
发表于 2022-10-31 18:16:36 | 显示全部楼层
易微联app上显示的局域网控制是指app自己的控制方式。
HA中和易微联app的控制方式没关系。
按说ha中是局域网控制的,不放心你把ha断网试下就知道了。
我不生产技术,我只是技术的搬运工。
Emin 手机认证
 楼主| 发表于 2022-10-31 19:31:09 | 显示全部楼层
HA中和易微联app的控制方式没关系。
按说ha中是局域 ...
断网后按钮都变成了灰色色,就是控制不了。是不是我哪儿设置有问题
发表于 2022-10-31 19:58:52 | 显示全部楼层
你用什么插件集成进来的?
我不生产技术,我只是技术的搬运工。
Emin 手机认证
 楼主| 发表于 2022-10-31 21:14:10 | 显示全部楼层
zxyny1989 发表于 2022-10-31 19:58
你用什么插件集成进来的?
sonofflan,地址:https://github.com/AlexxIT/SonoffLAN/
发表于 2022-10-31 21:27:33 | 显示全部楼层
Tested (LAN and Cloud)
These devices work both on a local network and through the cloud.
    Sonoff Basic, BASICR2, BASICR3, RFR2, RFR3
    Sonoff Mini, MINI R3 (no need use DIY-mode)
    Sonoff Micro
    Sonoff TH10/TH16 (support Thermostat)
    Sonoff 4CH, 4CHR2, 4CHR3 & 4CHPROR3
    Sonoff POWR2 (show power consumption)
    Sonoff DUALR3/DUALR3 Lite
    Sonoff RF Bridge 433 (receive and send commands) fw 3.5.0
    Sonoff D1 (dimmer with brightness control) fw 3.4.0, 3.5.0
    Sonoff G1 fw 3.5.0
    Sonoff Dual
    Sonoff iFan02, iFan03, iFan04 (light and fan with speed control) fw 3.4.0
    Sonoff S20, S26, S31, S55
    Sonoff SV fw 3.0.1
    Sonoff T1, TX Series
    Sonoff T4EU1C
    Sonoff IW100/IW101
    Sonoff Slampher R2
    Sonoff 5V DIY
    Sonoff RE5V1C
    Sonoff NSPanel
    MiniTiger Wall Switch (I have 8 without zero-line) fw 3.3.0
    Smart Circuit Breaker, link, link
    Smart Timer Switch
    Eachen WiFi Smart Touch fw 3.3.0
Tested (only Cloud)
These devices only work through the cloud!
    Sonoff POW (first) fw 2.6.1
    Sonoff L1 (color, brightness, effects) fw 2.7.0
    Sonoff B1 (color, brightness, color temp) fw 2.6.0
    Sonoff B02, B05-B, B05-BL
    Sonoff SC (five sensors) fw 2.7.0
    Sonoff DW2
    Sonoff SwitchMan R5
    Sonoff S-MATE
    Sonoff S40
    King Art - King Q4 Cover (pause, position) fw 2.7.0
    KING-M4 (brightness) fw 2.7.0
    Eachen WiFi Door/Window Sensor
    Essential Oils Diffuser (fan and color light) fw 2.9.0
    Smart USB Mosquito Killer
    Smart Bulb RGB+CCT
Tested ZigBee (only Cloud)
    Sonoff ZigBee Bridge - turn on for pairing mode
    SONOFF SNZB-01 - Zigbee Wireless Switch
    SONOFF SNZB-02 - ZigBee Temperature and Humidity Sensor
    SONOFF SNZB-03 - ZigBee Motion Sensor
    SONOFF SNZB-04 - ZigBee Wireless door/window sensor
Tested Cameras (only LAN)
Maybe other eWeLink cameras also work, I don’t know.
    Camera GK-100CD10B (camera with PTZ)
    Sonoff GK-200MP2-B (camera with PTZ)
看下说明吧,可能只能走云端吧。
我最早的都是本地的,后来新增的还没注意看。
我不生产技术,我只是技术的搬运工。
Emin 手机认证
 楼主| 发表于 2022-10-31 21:29:54 | 显示全部楼层
就是不知道图片那个模块是属于说明里面的哪种设备,在ha里面可以查看到相关信息吗?
发表于 2022-10-31 21:36:03 | 显示全部楼层
Emin 发表于 2022-10-31 21:29
就是不知道图片那个模块是属于说明里面的哪种设备,在ha里面可以查看到相关信息吗? ...
需要打开蓝牙配对的吧?
如果是就放弃吧,本地接入需要用兼容模式并获取key的
我不生产技术,我只是技术的搬运工。
Emin 手机认证
 楼主| 发表于 2022-10-31 21:39:34 | 显示全部楼层
zxyny1989 发表于 2022-10-31 21:36
需要打开蓝牙配对的吧?
如果是就放弃吧,本地接入需要用兼容模式并获取key的 ...
需不需要蓝牙配对不清楚,手机蓝牙是一直打开的。所有的Key我在.storage/sonoff下的json文件里找到了,如果要设置局域网,应该如何操作呢
GMT+8, 2025-11-2 16:56 , Processed in 0.200541 second(s), 6 queries , MemCached On.
