查看: 4364|回复: 6
[技术探讨] 求助大神,立新电表Wi-Fi版接入能源后无法统计费用
发表于 2022-10-31 10:19:28 | 显示全部楼层 |阅读模式
立新wifi版通过local涂鸦接入ha,电量统计都是正常的,但是电费一直无法正常显示,状态显示nan,无论设置固定电价还是实时电价都不行。
发表于 2022-10-31 10:33:35 | 显示全部楼层
不用监测电费啊,再说那个也不准。
自己写template计算.
  #今日电费
  - platform: template
    sensors:
      jinri_dianfei:
        unit_of_measurement: "RMB"
        value_template: >
          {% if now().month in [1,3,5,7,8,10,12] %}
          {% set date = (31 - now().day) %}
          {% elif now().month in [4,6,9,11] %}
          {% set date = (30 - now().day) %}
          {% elif now().month == 2 and ((now().year-2000) % 4 > 0) %}
          {% set date = (28 - now().day) %}
          {% elif now().month == 2 and ((now().year-2000) % 4 == 0) %}
          {% set date = (29 - now().day) %}
          {% endif %}
          {% if (date != 0 and (states("sensor.ben_nian_du_yong_dian") | float - states("sensor.jin_ri_yong_dian") | float + (states("sensor.zuo_ri_dianliang") | float * (date + 1))) | int > 3120) or (date == 0 and states("sensor.ben_nian_du_yong_dian") | int > 3120) %}
          {{(states("sensor.jin_ri_yong_dian") | float * 0.86) | round(2)}}
          {% elif (date != 0 and (states("sensor.ben_nian_du_yong_dian") | float - states("sensor.jin_ri_yong_dian") | float + (states("sensor.zuo_ri_dianliang") | float * (date + 1))) | int > 2160) or (date == 0 and states("sensor.ben_nian_du_yong_dian") | int > 2160) %}
          {{(states("sensor.jin_ri_yong_dian") | float * 0.61) | round(2)}}
          {% else %}
          {{(states("sensor.jin_ri_yong_dian") | float * 0.56) | round(2)}}
          {% endif %}
#总电费
    sensors:
      zongdianfei:
        value_template: >
          {% endif %}
          {{(states("sensor.ben_nian_du_yong_dian") | float * 0.86) | round(2)}}
          {{(states("sensor.ben_nian_du_yong_dian") | float * 0.61) | round(2)}}
          {% else %}
          {{(states("sensor.ben_nian_du_yong_dian") | float * 0.56) | round(2)}}
          {% endif %}
#当前阶梯
    sensors:
      dang_qian_jie_ti:
        unit_of_measurement: "L"
        value_template: >
          {% if states("sensor.ben_nian_du_yong_dian") | float <= 2160 %}
          {% elif states("sensor.ben_nian_du_yong_dian") | float >2160  and states("sensor.ben_nian_du_yong_dian") | float <= 3120 %}
          {% elif states("sensor.ben_nian_du_yong_dian") | float > 3120 %}
          {% else %}
          {% endif %}
        friendly_name:  '当前阶梯'
我不生产技术,我只是技术的搬运工。
发表于 2023-1-16 15:51:56 | 显示全部楼层
zxyny1989 发表于 2022-10-31 10:33
不用监测电费啊,再说那个也不准。
自己写template计算.
你好,如果是每个月按照使用电量作为阶梯的能用吗?
发表于 2023-1-19 01:58:16 | 显示全部楼层
自己写template
我不生产技术,我只是技术的搬运工。
发表于 2023-1-25 08:23:31 | 显示全部楼层
好东西,留言备用
发表于 2023-1-25 12:40:43 | 显示全部楼层
很好,备用。
发表于 2023-3-7 19:15:13 | 显示全部楼层
wifi版如何接入呢
GMT+8, 2025-12-12 21:50 , Processed in 0.081233 second(s), 16 queries , MemCached On.
