查看: 3576|回复: 2
[求助] node-red的两种安装方法有什么不同
发表于 2022-10-21 12:04:20 | 显示全部楼层 |阅读模式
hacs下安装node-red集成跟add ones 加载项上安装node-red 的有什么不同吗?
发表于 2022-10-21 13:43:59 | 显示全部楼层
hacs下面安装的是Node-RED Companion,你可以在hacs的Node-RED Companion集成介绍页面看到,他说的这个集成是辅助addon里面的node-red的
This integration will give Node-RED the ability to create/update binary sensors, sensors and switches in Home Assistant. Event nodes in Node-RED can be exposed to Home Assistant as switches which will allow them to enable and disable flows from the Home Assistant UI or service calls.
Must have node-red-contrib-home-assistant-websocket installed in Node-RED. (minimum version 0.20)
发表于 2022-10-22 11:16:04 来自手机 | 显示全部楼层
不是一个东西,HACS的是NR辅助工具,比如你在NR建了个开关实体,HA可以直接用
GMT+8, 2025-12-16 19:54 , Processed in 0.947998 second(s), 5 queries , MemCached On.
