查看: 1941|回复: 2
[求助] yeelight屏幕挂灯官方插件接入,调色日志报错
发表于 2022-10-17 21:34:15 | 显示全部楼层 |阅读模式
Logger: homeassistant.components.websocket_api.http.connection
Source: components/yeelight/light.py:265
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 21:27:03 (11 occurrences)
Last logged: 21:30:44
[140144017334208] Error when calling async_set_default for bulb Yeelight Lamp15 0x1c0fbfe8 at 192.168.31.92: {'code': -5006, 'message': 'illegal request'}
[140144012852432] Error when calling async_set_default for bulb Yeelight Lamp15 0x1c0fbfe8 at 192.168.31.92: {'code': -5006, 'message': 'illegal request'}
  File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 245, in _async_wrap
    return await func(self, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 704, in async_set_default
    await self._bulb.async_set_default()
  File "/usr/local/lib/python3.10/site-packages/yeelight/aio.py", line 38, in wrapper
    cmd = await self.async_send_command(
  File "/usr/local/lib/python3.10/site-packages/yeelight/aio.py", line 96, in async_send_command
    raise BulbException(response["error"])
yeelight.main.BulbException: {'code': -5006, 'message': 'illegal request'}
The above exception was the direct cause of the following exception:
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1738, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1775, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 676, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 931, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 713, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 535, in async_handle_light_on_service
    await light.async_turn_on(**filter_turn_on_params(light, params))
  File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 802, in async_turn_on
    await self.async_set_default()
  File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 265, in _async_wrap
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error when calling async_set_default for bulb Yeelight Lamp15 0x1c0fbfe8 at 192.168.31.92: {'code': -5006, 'message': 'illegal request'}
 楼主| 发表于 2022-10-17 21:36:20 | 显示全部楼层
调色板改颜色左下角提示
调用服务 light/turn_on 失败。 Error when calling async_set_default for bulb Yeelight Lamp15 0x1c0fbfe8 at 192.168.31.92: {'code': -5006, 'message': 'illegal request'}
 楼主| 发表于 2022-10-17 21:37:30 | 显示全部楼层
虽然报错,但是颜色确实改了。。。另外日志里还有其他一些错误,但是运行没有问题。。。这样有关系吗
GMT+8, 2025-12-16 20:05 , Processed in 0.986460 second(s), 7 queries , MemCached On.
