查看: 3327|回复: 1
[技术探讨] ESP modbus 求助
发表于 2022-10-17 17:51:07 | 显示全部楼层 |阅读模式
我也碰到同样的问题,一个ESP32s读取address: 0xd6 或者address: 0xd7 着两个同一总线上的两个不同地址设备,读取任意一个都没有问题但是读取两个设备,ESP直接挂了连接不上API。目前采取的办法是使用了两个ESP分别读取单个设备的办法解决,但着终究不是个事总不能增加一个MODBUS设备就占用一个ESP硬件把,那位大神帮忙看看那里出问题了!
modbus:
  send_wait_time: 2000ms
modbus_controller:
  - id: esp485_modbus_controller
    modbus_id: esp485_modbus
    address: 0xd6
    command_throttle: 2000ms
    setup_priority: -8
    update_interval: 5s
  - id: esp485_modbus_controller_01
    address: 0xd7
    command_throttle: 1500ms
    setup_priority: -10
    update_interval: 10s
  #母排电压
  - platform: modbus_controller
    modbus_controller_id: esp485_modbus_controller
    address: 0x0000
    unit_of_measurement: "V"
    register_type: holding
    value_type: U_WORD
    accuracy_decimals: 2
    filters:
    - multiply: 0.01
    device_class: voltage
#电池01
    modbus_controller_id: esp485_modbus_controller_01
    address: 0x0000
    value_type: U_WORD
    filters:
    - multiply: 0.01
发表于 2022-12-10 18:01:28 | 显示全部楼层
我也遇到现样的问题,家里有8个mudbus温控器,都设置成不同的地址码,接入1个没问题,接入2个只能显示一个,你的问题解决了吗?我的代码如下:
## 配置mod_bus
#  配置mod_bus设置
uart:
  - id: mod_bus
    baud_rate: 9600 # speed to STC15L101EW
    stop_bits: 1
    tx_pin: GPIO1
    rx_pin: GPIO3
# 配置mod_bus日志文件
    debug:
      direction: BOTH
      dummy_receiver: false
      after:
        delimiter: "\n"
      sequence:
        - lambda: UARTDebug::log_string(direction, bytes);  ##  UARTDebug::log_hex(direction, bytes, char separator)  将字节记录为字符串值
modbus:
   - id: mod_bus_1
     send_wait_time: 200ms
   - id: mod_bus_2
   - id: mod_bus_3
   - id: mod_bus_4
   - id: mod_bus_5
   - id: mod_bus_6
   - id: mod_bus_7
   - id: mod_bus_8
   - id: mod_bus_10
modbus_controller:
  - id: elex_1                     #客厅空调温控器
    address: 0x1
    modbus_id: mod_bus_1
    setup_priority: -10
    update_interval: 2s
  - id: elex_2                     #餐厅空调温控器
    address: 0x2
    modbus_id: mod_bus_2
    setup_priority: -10
    update_interval: 2s
  - id: elex_3                     #主卧空调温控器
    address: 0x3
    modbus_id: mod_bus_3
    setup_priority: -10
    update_interval: 2s
  - id: elex_4                     #次卧空调温控器
    address: 0x4
    modbus_id: mod_bus_4
    setup_priority: -10
    update_interval: 2s
  - id: elex_5                     #客卧空调温控器
    address: 0x5
    modbus_id: mod_bus_5
    setup_priority: -10
    update_interval: 2s
  - id: elex_6                     #书房空调温控器
    address: 0x6
    modbus_id: mod_bus_6
    setup_priority: -10
    update_interval: 2s
  - id: elex_7                     #地暖控制器
    address: 0x7
    modbus_id: mod_bus_7
    setup_priority: -10
    update_interval: 2s
  - id: elex_8                     #新风控制器
    address: 0x8
    modbus_id: mod_bus_8
    setup_priority: -10
    update_interval: 2s
  - id: elex                      #机柜测试温控器
    address: 0xA
    modbus_id: mod_bus_10
    setup_priority: -10
    update_interval: 2s
switch:
## 设置温控器开关
    modbus_controller_id: elex_1
    address: 0x1
    bitmask: 1
    modbus_controller_id: elex_2
    address: 0x1
    bitmask: 1
#读取温控器设置
    address: 0x06
    unit_of_measurement: "°C"
    value_type: S_WORD
    accuracy_decimals: 1
    skip_updates: 1
#    filters:
#      - multiply: 0.01
GMT+8, 2026-1-25 08:42 , Processed in 0.689037 second(s), 11 queries , MemCached On.
