查看: 5478|回复: 5
[求助] HomeAssistant拒绝外网登录
发表于 2022-10-14 11:24:43 | 显示全部楼层 |阅读模式
昨天把hassos更新最新版后外网就无法登录了,具体症状为外网能访问登录页面,但是被拒绝登录,
有大佬知道什么问题怎么解决吗?下面为系统版本信息:
Home Assistant 2022.10.3
Supervisor 2022.10.0
Operating System 9.2
前端版本: 20221010.0 - latest
下面为登录异常截图(网页和手机app报同样错误):
下面为通知homeassistant通知详情:
Login attempt failed
Login attempt or request with invalid authentication from 113.89.**.100 (113.89.**.100). See the log for details.
下面为系统日志:
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:82
Integration: HTTP (documentation, issues)
First occurred: 10:38:24 (4 occurrences)
Last logged: 11:11:53
Login attempt or request with invalid authentication from 14.26.21.159 (14.26.21.159). Requested URL: '/auth/login_flow/a6af024cb6d0790b60670102d0be49a6'. (Mozilla/5.0 (Linux; Android 12; LIO-AL00 Build/HUAWEILIO-AL00; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/92.0.4515.105 Mobile Safari/537.36 Home Assistant/2022.10.0-2738 (Android 12; LIO-AL00))
Login attempt or request with invalid authentication from 14.26.21.159 (14.26.21.159). Requested URL: '/auth/login_flow/960a980364b19515631d8af53d30d0ef'. (Mozilla/5.0 (Linux; Android 12; LIO-AL00 Build/HUAWEILIO-AL00; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/92.0.4515.105 Mobile Safari/537.36 Home Assistant/2022.10.0-2738 (Android 12; LIO-AL00))
Login attempt or request with invalid authentication from 14.26.21.159 (14.26.21.159). Requested URL: '/auth/login_flow/711feee8dcde7bedeff658b4ccff86c1'. (Mozilla/5.0 (Linux; Android 12; LIO-AL00 Build/HUAWEILIO-AL00; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/92.0.4515.105 Mobile Safari/537.36 Home Assistant/2022.10.0-2738 (Android 12; LIO-AL00))
Login attempt or request with invalid authentication from 113.89.43.100 (113.89.43.100). Requested URL: '/auth/login_flow/76e8c81f434fb682cad036076a25bd0a'. (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36 Edg/106.0.1370.42)
发表于 2022-10-14 14:43:28 | 显示全部楼层
看下 配置-人员-只允许从本地网络登录-点自己账户-只允许从本地网络登录 是不是打开了
参与人数 1金钱 +10 收起 理由
虫虫不咬人 + 10 高手,这是高手!
发表于 2022-10-14 11:54:04 | 显示全部楼层
是不是这个没配置引起的,那个IP及掩码好像根据自己的报错情况配置
参与人数 1金钱 +10 收起 理由
虫虫不咬人 + 10 赠人玫瑰,手留余香!
 楼主| 发表于 2022-10-14 15:46:24 | 显示全部楼层
OliverY 发表于 2022-10-14 14:43
看下 配置-人员-只允许从本地网络登录-点自己账户-只允许从本地网络登录 是不是打开了 ...
还真是被打开了,感谢大佬
发表于 2024-7-19 17:54:05 | 显示全部楼层
没有打开呀 还是无法登录
发表于 2025-3-5 10:40:03 | 显示全部楼层
优质天使 发表于 2024-7-19 17:54
没有打开呀 还是无法登录
重新添加一个人员进去,然后新添加的人员可以外网登陆,具体原因我也不知道
GMT+8, 2025-12-17 04:53 , Processed in 0.865915 second(s), 14 queries , MemCached On.
