查看: 3757|回复: 10
[技术探讨] 在docker安装的esphome里,用esp32能通过验证,上传时报错
发表于 2022-10-13 10:14:52 来自手机 | 显示全部楼层 |阅读模式
docker安装的esphome里,用esp32能通过验证,上传时报错。之前都正常。哪位大神指点问题所在
INFO Reading configuration /config/esp32.yaml...
INFO Detected timezone 'Asia/Shanghai'
WARNING GPIO0 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO4 is a Strapping PIN and should be avoided.
INFO Generating C++ source...
INFO Compiling app...
Processing esp32 (board: nodemcu-32s; framework: arduino; platform: platformio/espressif32 @ 3.5.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- <AsyncTCP-esphome> 1.2.2
|-- <WiFi> 1.0
|-- <FS> 1.0
|-- <Update> 1.0
|-- <ESPAsyncWebServer-esphome> 2.1.0
|   |-- <AsyncTCP-esphome> 1.2.2
|-- <DNSServer> 1.1.0
|-- <ESPmDNS> 1.0
|-- <ArduinoJson> 6.18.5
Compiling .pioenvs/esp32/src/esphome/components/adc/adc_sensor.cpp.o
Compiling .pioenvs/esp32/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/esp32/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/esp32/src/esphome/components/api/api_pb2.cpp.o
xtensa-esp32-elf-g++: internal compiler error: Segmentation fault (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
*** [.pioenvs/esp32/src/esphome/components/api/api_connection.cpp.o] Error 4
*** [.pioenvs/esp32/src/esphome/components/api/api_frame_helper.cpp.o] Error 4
========================= [FAILED] Took 29.38 seconds =========================
水平有限望指教!!
发表于 2022-10-13 22:38:47 | 显示全部楼层
把你的.yam丢上来  gpio0 和 gpio4
 楼主| 发表于 2022-10-14 08:47:31 来自手机 | 显示全部楼层
关键是下面报错的内容
智能家居&单板滑雪痴迷爱好者
发表于 2022-10-14 16:26:57 | 显示全部楼层
关键是这一句:xtensa-esp32-elf-g++: internal compiler error: Segmentation fault,内部编译器错误。
你是在什么平台上跑的esphome?哪个版本?
 楼主| 发表于 2022-10-17 03:25:28 来自手机 | 显示全部楼层
N1docker下安装的esphome。编辑器错误怎样解决?望指教!
智能家居&单板滑雪痴迷爱好者
发表于 2022-10-17 08:03:44 | 显示全部楼层
很多人说过的问题,交叉编译,需要平台的支持。
N1的处理器是arm,没这个能力。
在x86平台上部署一个esphome吧。
 楼主| 发表于 2022-10-18 10:31:22 来自手机 | 显示全部楼层
版本是2022.9.4的
 楼主| 发表于 2022-10-18 10:33:55 来自手机 | 显示全部楼层
之前都可以用的,编译上传都正常
发表于 2022-10-18 10:39:49 | 显示全部楼层
我的n1和我家云docker安装esphome,都出现这些问题。估计还是arm平台不支持。。。
发表于 2022-10-18 10:41:16 | 显示全部楼层
bhc1365 发表于 2022-10-18 10:33
之前都可以用的,编译上传都正常
确实有这种情况,大多数8266和普通esp32的yaml可以支持编译,但某些代码就不支持报错。。。
GMT+8, 2025-12-1 18:52 , Processed in 1.262047 second(s), 9 queries , MemCached On.
