查看: 13567|回复: 34
ESPsonoff 加装DHT22 温湿度
发表于 2017-5-21 14:56:58 | 显示全部楼层 |阅读模式
  Copyright (c) 2017 @KmanOz
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files (the "Software"), to deal
  in the Software without restriction, including without limitation the rights
  to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
  copies of the Software, and to permit persons to whom the Software is
  furnished to do so, subject to the following conditions:
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
  THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
  IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
  FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
  AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
  LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
  OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
  SOFTWARE.
  Changes in v1.01
    - Relay state now stored in EEPROM and will power up with last relay state
    - Remote ON & OFF via Wallswitch on pin 14. No debounce provided. Assumes
      operation via proper electrical wallswitch which has mechanical debounce.
  **** USE THIS Firmware for: Sonof TH10/16 and additional wallswitch ****
#include <EEPROM.h>
#include <ESP8266WiFi.h>
#include <;PubSubClient.h>
#include <Ticker.h>
#define BUTTON          0                                    // (Don't Change for Sonoff TH Series)
#define RELAY           12                                   // (Don't Change for Sonoff TH Series)
#define LED             13                                   // (Don't Change for Sonoff TH Series)
#define WALLSWITCH      14                                   // (Don't Change for Sonoff TH Series)
#define MQTT_CLIENT     "Sonoff_Living_Room_v1.0p"           // mqtt client_id (Must be unique for each Sonoff)
#define MQTT_SERVER     "192.168.0.100"                      // mqtt server
#define MQTT_PORT       1883                                 // mqtt port
#define MQTT_TOPIC      "home/sonoff/living_room/1"          // mqtt topic (Must be unique for each Sonoff)
#define MQTT_USER       "user"                               // mqtt user
#define MQTT_PASS       "pass"                               // mqtt password
#define WIFI_SSID       "homewifi"                           // wifi ssid
#define WIFI_PASS       "homepass"                           // wifi password
#define VERSION    "\n\n----------------  Sonoff TH Powerpoint v1.01p  -----------------"
bool rememberRelayState = true;                              // If 'true' remembers the state of the relay before power loss.
bool requestRestart = false;                                 // (Do not Change)
bool sendStatus = false;                                     // (Do not Change)
int kUpdFreq = 1;                                            // Update frequency in Mintes to check for mqtt connection
int kRetries = 10;                                           // WiFi retry count. Increase if not connecting to router.
int wallSwitch = 1;                                          // (Do not Change)
int lastWallSwitch = 1;                                      // (Do not Change)
int lastRelayState;                                          // (Do not Change)
unsigned long TTasks;                                        // (Do not Change)
unsigned long count = 0;                                     // (Do not Change)
extern "C" {
  #include "user_interface.h"
WiFiClient wifiClient;
PubSubClient mqttClient(wifiClient, MQTT_SERVER, MQTT_PORT);
Ticker btn_timer;
void callback(const MQTT::Publish& pub) {
  if (pub.payload_string() == "stat") {
  else if (pub.payload_string() == "on") {
    digitalWrite(RELAY, HIGH);
  else if (pub.payload_string() == "off") {
    digitalWrite(RELAY, LOW);
  else if (pub.payload_string() == "reset") {
    requestRestart = true;
  sendStatus = true;
void setup() {
  pinMode(LED, OUTPUT);
  pinMode(RELAY, OUTPUT);
  pinMode(BUTTON, INPUT);
  pinMode(WALLSWITCH, INPUT);
  digitalWrite(LED, HIGH);
  Serial.begin(115200);
  EEPROM.begin(8);
  lastRelayState = EEPROM.read(0);
  if (rememberRelayState && lastRelayState == 1) {
  btn_timer.attach(0.05, button);
  mqttClient.set_callback(callback);
  WiFi.mode(WIFI_STA);
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  Serial.println(VERSION);
  Serial.print("\nUnit ID: ");
  Serial.print("esp8266-");
  Serial.print(ESP.getChipId(), HEX);
  Serial.print("\nConnecting to "); Serial.print(WIFI_SSID); Serial.print(" Wifi");
  while ((WiFi.status() != WL_CONNECTED) && kRetries --) {
    delay(500);
    Serial.print(" .");
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println(" DONE");
    Serial.print("IP Address is: "); Serial.println(WiFi.localIP());
    Serial.print("Connecting to ");Serial.print(MQTT_SERVER);Serial.print(" Broker . .");
    delay(500);
    while (!mqttClient.connect(MQTT::Connect(MQTT_CLIENT).set_keepalive(90).set_auth(MQTT_USER, MQTT_PASS)) && kRetries --) {
      Serial.print(" .");
      delay(1000);
    if(mqttClient.connected()) {
      Serial.println("\n----------------------------  Logs  ----------------------------");
      Serial.println();
      mqttClient.subscribe(MQTT_TOPIC);
      blinkLED(LED, 40, 8);
      digitalWrite(LED, LOW);
    else {
      Serial.println(" FAILED!");
      Serial.println("\n----------------------------------------------------------------");
      Serial.println();
  else {
    Serial.println(" WiFi FAILED!");
    Serial.println();
void loop() {
  mqttClient.loop();
  timedTasks();
  checkStatus();
  checkWallSwitch();
void blinkLED(int pin, int duration, int n) {
  for(int i=0; i<n; i++)  {
    digitalWrite(pin, HIGH);
    delay(duration);
    digitalWrite(pin, LOW);
    delay(duration);
void button() {
  if (!digitalRead(BUTTON)) {
    count++;
  else {
    if (count > 1 && count <= 40) {
      digitalWrite(RELAY, !digitalRead(RELAY));
      sendStatus = true;
    else if (count >40){
      Serial.println("\n\nSonoff Rebooting . . . . . . . . Please Wait");
    count=0;
void checkConnection() {
    if (mqttClient.connected()) {
      Serial.println("mqtt broker connection . . . . . . . . . . OK");
    else {
      Serial.println("mqtt broker connection . . . . . . . . . . LOST");
  else {
    Serial.println("WiFi connection . . . . . . . . . . LOST");
void checkStatus() {
  if (sendStatus) {
    if(digitalRead(RELAY) == LOW)  {
      if (rememberRelayState) {
        EEPROM.write(0, 0);
      mqttClient.publish(MQTT::Publish(MQTT_TOPIC"/stat", "off").set_retain().set_qos(1));
      Serial.println("Relay . . . . . . . . . . . . . . . . . . OFF");
    } else {
        EEPROM.write(0, 1);
      mqttClient.publish(MQTT::Publish(MQTT_TOPIC"/stat", "on").set_retain().set_qos(1));
      Serial.println("Relay . . . . . . . . . . . . . . . . . . ON");
      EEPROM.commit();
    sendStatus = false;
  if (requestRestart) {
    blinkLED(LED, 400, 4);
    ESP.restart();
void checkWallSwitch() {
  wallSwitch = digitalRead(WALLSWITCH);
  if (wallSwitch != lastWallSwitch) {
    sendStatus = true;
  lastWallSwitch = wallSwitch;
void timedTasks() {
  if ((millis() > TTasks + (kUpdFreq*60000)) || (millis() < TTasks)) {
    TTasks = millis();
    checkConnection();
温湿度传感器
Sonoff TH 10/16 -------------------------------
- platform: mqtt
  name: "Living Room Temp"
  state_topic: "home/sonoff/living_room/1/temp"
  qos: 1
  unit_of_measurement: "°C"
  value_template: "{{ value_json.Temp }}"
- platform: mqtt
  name: "Living Room Humidity"
  qos: 1
  unit_of_measurement: "%"
  value_template: "{{ value_json.Humidity }}"
Sonoff Pow -------------------------------------
- platform: mqtt
  name: "Living Room Power"
  state_topic: "home/sonoff/living_room/1/power"
  qos: 1
  unit_of_measurement: "W"
  value_template: "{{ value_json.Power }}"
- platform: mqtt
  name: "Living Room Voltage"
  qos: 1
  unit_of_measurement: "V"
  value_template: "{{ value_json.Voltage }}"
开关
switch:
  platform: mqtt
  state_topic: "home/sonoff/living_room/1/stat"
  command_topic: "home/sonoff/living_room/1"
  qos: 1
  payload_on: "on"
  payload_off: "off"
  retain: true
wqqs 手机认证
活跃会员
发表于 2017-5-21 16:59:44 | 显示全部楼层
谢谢分享!!!
发表于 2017-5-21 17:36:30 | 显示全部楼层
感谢分享,大家都是好样的
发表于 2017-5-21 18:10:54 | 显示全部楼层
感谢分享,大家都是好样的
发表于 2017-5-21 19:54:41 | 显示全部楼层
这个可以有,感谢分享
wzcx
发表于 2017-5-21 20:31:31 | 显示全部楼层
谢谢分享,支持!
发表于 2017-5-22 11:17:46 来自手机 | 显示全部楼层
谢谢分享!
发表于 2017-5-22 16:12:45 | 显示全部楼层
请问第一段代码用什么软件烧写在哪个硬件上的?谢谢!
发表于 2017-5-22 21:59:07 来自手机 | 显示全部楼层
都是高手啊
发表于 2017-5-25 06:19:37 来自手机 | 显示全部楼层
谢谢分享!
GMT+8, 2025-9-4 20:40 , Processed in 1.321782 second(s), 10 queries , MemCached On.
