查看: 2859|回复: 3
[求助] 大佬们,为何手机版HA无法登陆?
发表于 2022-10-8 09:58:30 | 显示全部楼层 |阅读模式
手机网页浏览器、电脑浏览器内网外网登陆都正常、homeassistant的app在内网登陆也可以,但外网用手机版的homeassistant登陆就报错 显示反馈无效外网登陆用的是DDNSTO
 楼主| 发表于 2022-10-8 10:03:12 | 显示全部楼层
Logger: homeassistant.components.webhook
Source: components/mobile_app/helpers.py:45
Integration: Webhook (documentation, issues)
First occurred: 09:19:16 (48 occurrences)
Last logged: 10:02:33
Error processing webhook 70b8ba54850d19a31c43df963ad2537c1fe137b06daf022707b2f57befeb4d9e
Error processing webhook 51172201a4f0fd07852f4af81f090e5213610aee1cadcda839a06dc79690f798
Error processing webhook 3a99ef0deb7f00e6fdc82a74b60908a1be907ee20b76ea6b292056f4dff4ea1b
  File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 104, in async_handle_webhook
    response = await webhook["handler"](hass, webhook_id, request)
  File "/usr/src/homeassistant/homeassistant/components/mobile_app/webhook.py", line 193, in handle_webhook
    webhook_payload = _decrypt_payload(config_entry.data[CONF_SECRET], enc_data)
  File "/usr/src/homeassistant/homeassistant/components/mobile_app/helpers.py", line 80, in _decrypt_payload
    message = decrypt(ciphertext, key)
  File "/usr/src/homeassistant/homeassistant/components/mobile_app/helpers.py", line 45, in decrypt
    return SecretBox(key).decrypt(ciphertext, encoder=Base64Encoder)
  File "/usr/local/lib/python3.9/site-packages/nacl/secret.py", line 130, in decrypt
    plaintext = nacl.bindings.crypto_secretbox_open(ciphertext,
  File "/usr/local/lib/python3.9/site-packages/nacl/bindings/crypto_secretbox.py", line 77, in crypto_secretbox_open
    ensure(res == 0, "Decryption failed. Ciphertext failed verification",
  File "/usr/local/lib/python3.9/site-packages/nacl/exceptions.py", line 81, in ensure
    raise raising(*args)
nacl.exceptions.CryptoError: Decryption failed. Ciphertext failed verification
发表于 2022-10-12 00:00:12 来自手机 | 显示全部楼层
直接开放的端口用于外网访问还是反代? 如果是反代需要设置WebSocket
发表于 2023-1-14 14:25:25 | 显示全部楼层
感觉应该是app版本升级后,不兼容了
GMT+8, 2025-12-17 06:32 , Processed in 1.072305 second(s), 14 queries , MemCached On.
