查看: 4667|回复: 5
[技术探讨] ESPURNA zm1 ztc1 怎么添加Homeassistant mqtt已连接
发表于 2022-10-2 01:23:51 | 显示全部楼层 |阅读模式
ESPURNA  HASS中显示的代码复制到configuration.yaml 报错了怎么修改?
 楼主| 发表于 2022-10-2 02:16:57 | 显示全部楼层
ZM1代码怎么加到Hass?
  - platform: mqtt
    # friendly_name: 温度
    state_topic: 'device/zm1/MACMAC/sensor'
    unit_of_measurement: '°C'
    icon: 'mdi:thermometer'
    value_template: '{{ value_json.temperature }}'
  - platform: mqtt
    # friendly_name: 湿度
    unit_of_measurement: '%'
    icon: mdi:water-percent
    value_template: '{{ value_json.humidity }}'
  - platform: mqtt
    # friendly_name: PM25
    unit_of_measurement: 'μg/m³'
    icon: mdi:blur
    value_template: '{{ value_json.PM25 }}'
  - platform: mqtt
    # friendly_name: 甲醛
    unit_of_measurement: 'mg/m³'
    icon: mdi:chemical-weapon
    value_template: '{{ value_json.formaldehyde }}'
light:
  - platform: mqtt
    schema: template
    command_topic: "device/zm1/MACMAC/set"
    state_topic: "device/zm1/MACMAC/state"
    command_on_template: >
      {"mac": "MACMAC"
      {%- if brightness is defined -%}
      , "brightness": {{ ((brightness-1) / 64 )|int +1 }}
      {%- else -%}
      , "brightness": 4
      {%- endif -%}
    command_off_template: '{"mac": "MACMAC", "brightness": 0}'
    state_template: >
      {%- if value_json.brightness == 0 -%}
        off
      {%- else -%}
        on
      {%- endif -%}
    brightness_template: >
      {%- if value_json.brightness is defined -%}
        {{ ( value_json.brightness *64 )|int }}
      {%- endif -%}
homeassistant:
  customize:
    light.zm1_MACMAC_brightness:
      friendly_name: 卧室M1亮度
    sensor.zm1_MACMAC_temperature:
      friendly_name: 卧室温度
    sensor.zm1_MACMAC_humidity:
      friendly_name: 卧室湿度
    sensor.zm1_MACMAC_pm25:
      friendly_name: 卧室PM2.5
    sensor.zm1_MACMAC_hcho:
      friendly_name: 卧室甲醛
发表于 2022-10-2 20:28:02 | 显示全部楼层
1、使用新的mqtt写法,不然明年就用不了了。
2、 state_topic: 'device/zm1/MACMAC/sensor'    MACMAC改成自己M1的mac地址
mqtt:
    - name: 'zm1_MACMAC_temperature'
      # friendly_name: 温度
    - name: 'zm1_MACMAC_humidity'
      # friendly_name: 湿度
    - name: 'zm1_MACMAC_pm25'
      icon: mdi:blur
    - name: 'zm1_MACMAC_hcho'
      # friendly_name: 甲醛
  light:
    - name: zm1_MACMAC_brightness
      schema: template
        {"mac": "MACMAC"
        {%- else -%}
        , "brightness": 4
        {%- endif -%}
      state_template: >
          off
        {%- else -%}
          on
        {%- endif -%}
        {%- endif -%}
homeassistant:
  customize:
      friendly_name: 卧室温度
      friendly_name: 卧室湿度
      friendly_name: 卧室甲醛
参与人数 1金钱 +5 收起 理由
lqf1206 + 5 在下对你的景仰犹如滔滔长江之水,连绵不绝.
我不生产技术,我只是技术的搬运工。
发表于 2022-10-5 17:47:41 | 显示全部楼层
多谢大佬~已搞定~~~
发表于 2022-10-11 23:50:07 | 显示全部楼层
 楼主| 发表于 2022-10-12 22:53:53 | 显示全部楼层
那里的问题?
GMT+8, 2026-1-18 08:07 , Processed in 0.983356 second(s), 15 queries , MemCached On.
