查看: 1538|回复: 0
[求助] hyper-V下的home assistant卡在页面
发表于 2022-9-29 12:25:18 | 显示全部楼层 |阅读模式
在官网上下载的hyper-V的虚拟硬盘,开机后显示正常,IP获取正常,但是在8123页面就一直提示:
[03:11:09] INFO: Using udev information from host
[03:11:09] INFO: Starting local supervisor watchdog...
22-09-29 03:11:15 INFO (MainThread) [__main__] Initializing Supervisor setup
22-09-29 03:11:15 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
22-09-29 03:11:16 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-09-29 03:11:16 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
22-09-29 03:11:16 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2022.08.6
22-09-29 03:11:16 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
22-09-29 03:11:17 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-09-29 03:11:17 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-09-29 03:11:17 INFO (MainThread) [__main__] Setting up Supervisor
22-09-29 03:11:28 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-09-29 03:11:28 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-09-29 03:11:28 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-09-29 03:11:28 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-09-29 03:11:28 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-09-29 03:11:28 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-09-29 03:11:28 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-09-29 03:11:29 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-09-29 03:11:29 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-09-29 03:11:29 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-09-29 03:11:29 INFO (MainThread) [supervisor.host.info] Updating local host information
22-09-29 03:11:29 INFO (MainThread) [supervisor.host.services] Updating service information
22-09-29 03:11:29 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-09-29 03:11:29 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-09-29 03:11:29 INFO (MainThread) [supervisor.host.network] Updating local network information
22-09-29 03:11:30 INFO (MainThread) [supervisor.host.network] Updating local network information
22-09-29 03:11:30 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-09-29 03:11:41 WARNING (MainThread) [supervisor.utils.whoami] Can't fetch Whoami data: Timeout
22-09-29 03:11:41 WARNING (MainThread) [supervisor.core] Can't adjust Time/Date settings: Can't fetch Whoami data: Timeout
22-09-29 03:11:41 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
22-09-29 03:11:41 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2022.08.0'>]
22-09-29 03:11:41 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.08.0
22-09-29 03:11:41 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
22-09-29 03:11:44 INFO (SyncWorker_1) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2022.08.0 - 172.30.32.5
22-09-29 03:11:44 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2022.04.1'>]
22-09-29 03:11:44 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
22-09-29 03:11:44 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
22-09-29 03:11:47 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1 - 172.30.32.3
22-09-29 03:11:47 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-09-29 03:11:58 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2022.07.0'>]
22-09-29 03:11:58 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
22-09-29 03:11:58 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
22-09-29 03:12:01 INFO (SyncWorker_1) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0 - 172.30.32.4
22-09-29 03:12:01 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2021.10.0'>]
22-09-29 03:12:01 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
22-09-29 03:12:01 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
22-09-29 03:12:04 INFO (SyncWorker_1) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0 - 172.30.32.6
22-09-29 03:12:04 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2022.02.0'>]
22-09-29 03:12:04 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
22-09-29 03:12:05 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
22-09-29 03:12:07 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0 - Host
22-09-29 03:12:07 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-09-29 03:12:07 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
22-09-29 03:12:07 INFO (SyncWorker_0) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/qemux86-64-homeassistant
22-09-29 03:12:07 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
22-09-29 03:12:07 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
22-09-29 03:12:07 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
22-09-29 03:12:07 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
22-09-29 03:12:07 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
22-09-29 03:12:09 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
22-09-29 03:12:09 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.0 / BootSlot A
22-09-29 03:12:09 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
22-09-29 03:12:09 ERROR (MainThread) [supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_RELOAD - ContextType.STORE / core
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
22-09-29 03:12:09 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/esphome/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_RELOAD - ContextType.STORE / 5c53de3b
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / 5c53de3b
22-09-29 03:12:09 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/hassio-addons/repository due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_RELOAD - ContextType.STORE / a0d7b954
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / a0d7b954
22-09-29 03:12:09 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
22-09-29 03:12:09 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-09-29 03:12:09 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-09-29 03:12:09 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-09-29 03:12:09 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-09-29 03:12:09 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-09-29 03:12:09 INFO (MainThread) [__main__] Running Supervisor
22-09-29 03:12:09 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
22-09-29 03:12:09 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-09-29 03:12:09 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
22-09-29 03:12:09 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
22-09-29 03:12:09 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
22-09-29 03:12:09 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
22-09-29 03:12:09 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-09-29 03:12:09 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-09-29 03:12:09 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
22-09-29 03:12:09 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-09-29 03:12:09 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-29 03:12:09 INFO (MainThread) [supervisor.host.info] Updating local host information
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-09-29 03:12:09 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-09-29 03:12:09 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
22-09-29 03:12:09 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-09-29 03:12:10 INFO (MainThread) [supervisor.host.services] Updating service information
22-09-29 03:12:10 INFO (MainThread) [supervisor.host.network] Updating local network information
22-09-29 03:12:10 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-09-29 03:12:10 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-09-29 03:12:20 WARNING (MainThread) [supervisor.utils.codenotary] rpc error: code = Unavailable desc = connection error: desc = "transport: authentication handshake failed: read tcp 172.17.0.2:54370->95.216.72.55:443: read: connection timed out"
22-09-29 03:12:20 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_INTEGRITY - ContextType.SYSTEM / None
22-09-29 03:12:20 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.TRUST - ContextType.SYSTEM / None
22-09-29 03:12:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-09-29 03:12:20 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
22-09-29 03:12:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-09-29 03:12:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
22-09-29 03:12:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-09-29 03:12:20 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
22-09-29 03:12:20 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-09-29 03:12:20 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-09-29 03:12:36 WARNING (MainThread) [supervisor.utils.codenotary] Timeout while processing CodeNotary
22-09-29 03:12:36 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-09-29 03:12:36 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-09-29 03:12:36 WARNING (MainThread) [supervisor.jobs] 'FixupSystemExecuteIntegrity.process_fixup' blocked from execution, no supervisor internet connection
22-09-29 03:12:36 WARNING (MainThread) [supervisor.jobs] 'FixupStoreExecuteReload.process_fixup' blocked from execution, no supervisor internet connection
22-09-29 03:12:36 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-09-29 03:12:39 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-09-29 03:12:39 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-29 03:13:09 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-09-29 03:13:09 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-29 03:13:39 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-09-29 03:13:39 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
请问大佬如何解决?
GMT+8, 2025-12-20 14:57 , Processed in 0.843170 second(s), 8 queries , MemCached On.
