查看: 3098|回复: 0
[硬件DIY] GPS ATGM332D接入ASSISTANT
发表于 2022-9-27 19:58:23 | 显示全部楼层 |阅读模式
型号如图,只要是标准的 NMEA通讯协议都可以通过esphome接入homeassistant,通讯只需要接一根TX到8266即可
O1CN01B0rIx929bRI76sPSX_!!1704768086.png_400x400.jpg     O1CN01GVvjJP29bRLkckmll_!!1704768086.png esphome代码很简单如下:
esphome:
  platform: ESP8266
  board: esp8285
# Enable logging
logger:
# Enable Home Assistant API
web_server:
  port: 80
ota:
  password: ""
wifi:
  networks:
  - ssid:
    password:
  - ssid:
    password:
  ap:
    ssid:
    password:
mqtt:
  broker:
  username:
  password:
captive_portal:
uart:
  rx_pin: 13
  baud_rate: 9600
# Declare GPS module
gps:
  latitude:
  longitude:
  altitude:
  speed:
  course:
  satellites:
然后可以通过NODERED,配合GPSLogger获取轨迹
GMT+8, 2026-1-18 11:42 , Processed in 0.248946 second(s), 8 queries , MemCached On.
