查看: 10560|回复: 23
[技术探讨] 有在openwrt docker里装ha的吗
发表于 2022-9-24 10:10:38 | 显示全部楼层 |阅读模式
请问一下你们的homekit正常不,为什么homekit设备接入不了ha,ha里桥接的设备苹果家庭里也搜索不到,需要怎么设置
发表于 2022-9-24 11:02:28 | 显示全部楼层
Docker Network Isolation
The advertise_ip option can be used to run this integration even inside an ephemeral Docker container with network isolation enabled, e.g., not using the host network.
You may need to set the default network interfaces Home Assistant uses, in its network configuration.
To use advertise_ip, add the option to your homekit configuration:
homekit:  advertise_ip: "STATIC_IP_OF_YOUR_DOCKER_HOST"
homekit:
Restart your Home Assistant instance. This feature requires running an mDNS forwarder on your Docker host, e.g., avahi-daemon in reflector mode.
Firewall
If you have a firewall configured on your Home Assistant system, make sure you open the following ports:
  • UDP: 5353
  • TCP: 21063 (or the configured/used port in the integration settings).
发表于 2022-9-24 11:13:55 | 显示全部楼层
以前用openwrt docker过。homekit死活找不到设备。host和bridge都不行,但是黑群docker就可以
发表于 2022-9-24 12:36:15 | 显示全部楼层
发表于 2022-9-24 14:17:57 | 显示全部楼层
容器网模式选择host,ha进配置/系统/网络,把
Auto Configure取消勾选,手动选择br-lan,openwrt因为是路由器环境原因,有多个网络,所以默认会不在lan口网段,所以hk添加不上
 楼主| 发表于 2022-9-25 00:46:37 来自手机 | 显示全部楼层
Auto Configure取消勾选,手动选择br-lan,openwrt因为是路由 ...
ha的网络打开是空白呢
 楼主| 发表于 2022-9-25 09:12:44 | 显示全部楼层
Kiyanda 发表于 2022-9-24 12:36
10楼完美解决方案
请问能在图形界面操作吗这样看不太懂
 楼主| 发表于 2022-9-25 09:13:45 | 显示全部楼层
哎呦不错哦 发表于 2022-9-24 11:13
以前用openwrt docker过。homekit死活找不到设备。host和bridge都不行,但是黑群docker就可以 ...
就是啊,我在黑群里没一点问题,但是不太想一直开着群晖
 楼主| 发表于 2022-9-25 09:15:59 | 显示全部楼层
befantasy 发表于 2022-9-24 11:02
Docker Network IsolationThe advertise_ip option can be used to run this integration even inside an e ...
没有看太懂,是在HA配置文件里加这2行代码吗
发表于 2022-9-25 09:48:56 | 显示全部楼层
好像是因为docker网络的问题  设置太麻烦了 我直接在vm虚拟机里面装了。
GMT+8, 2026-1-17 10:04 , Processed in 0.274719 second(s), 10 queries , MemCached On.
