查看: 3087|回复: 8
[技术探讨] 求助一下大佬 esphome 做无线开关
发表于 2022-9-21 18:00:13 | 显示全部楼层 |阅读模式
用esp8266 做无线开关 怎么识别 io口是单击 双击 长按呢 大佬可以写一段我抄一下吗
发表于 2022-9-21 20:02:20 | 显示全部楼层
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO3
      mode: INPUT_PULLUP
      inverted: true
    internal: true
    #按键点击操作中press与click(press + release)冲突,click的同时也会触发press,因此修改为如下的timing方式
    on_multi_click:
    #双击(x秒内按两下,松开按键0.2秒之后反馈状态)
    - timing:
        - ON for at most 0.5s
        - OFF for at most 0.5s
        - OFF for at least 0.2s
      then:
        - lambda: |-
            id(${node_id}_action).publish_state("double");
            id(${node_id}_switch_timeout).turn_on();
        - while:
            condition:
              lambda: |-
                return id(${node_id}_switch_timeout).state;
            then:
            - delay: 10ms
      invalid_cooldown: 0s
    #长按(按键时长为x秒到y秒之间,松开按键0.2秒之后发送状态)
    - timing:
        - ON for at least 0.7s
      then:
        - switch.toggle: ${node_id}_relay
    #短按(x秒内按一下,松开按键0.3秒之后反馈状态)
    #短按作为情景开关使用,不直接断开继电器...
    #...而是向服务器发送控制指令,由服务器关闭对指定设备进行遥控
    - timing:
        - ON for at most 0.3s
      then:
        - lambda: |-
            id(${node_id}_action).publish_state("single");
        - while:
            condition:
              lambda: |-
            then:
            - delay: 10ms
参与人数 1金钱 +8 收起 理由
sorrypqa + 8 论坛有你更精彩!
 楼主| 发表于 2022-9-22 08:43:56 | 显示全部楼层
szlww 发表于 2022-9-21 20:02
binary_sensor:
  - platform: gpio
    pin:
老哥谢谢你 给到我一个思路 非常感谢
 楼主| 发表于 2022-9-23 14:58:39 | 显示全部楼层
binary_sensor:
  - platform: gpio
    pin:
老哥我搞不掂呀 可以提示id不可以用这种字符附上配置希望可以帮忙改一下
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "IbFuJmYh3j38wgt0r41RD8tVSj42A1b1AwyZnxyhmxk="
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO3
      mode: INPUT_PULLUP
      inverted: true
    internal: true
    on_multi_click:
    - timing:
      then:
        - lambda: |-
        - while:
            condition:
              lambda: |-
            then:
            - delay: 10ms
    - timing:
      then:
    - timing:
      then:
        - lambda: |-
        - while:
            condition:
              lambda: |-
            then:
            - delay: 10ms
ota:
  password: "6aaa75f442e319c5f87c020dfdbfbc86"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Cs22 Fallback Hotspot"
    password: "w81VnRFNHVLi"
captive_portal:
 楼主| 发表于 2022-9-23 18:30:19 | 显示全部楼层
搞掂了 用mqtt 发报文ok了
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO14
      mode: INPUT_PULLUP
      inverted: true
    internal: true
    on_multi_click:
    - timing:
      then:
      - mqtt.publish:
          topic: esphome32/senso/ir
          payload: "double"
    - timing:
      then:
      - mqtt.publish:
          payload: "single"
    - timing:
      then:
      - mqtt.publish:
          payload: "hold"
    - timing:
      then:
      - mqtt.publish:
          payload: "Not_hold"
发表于 2022-9-23 19:53:36 来自手机 | 显示全部楼层
怎样解决这错误?
 楼主| 发表于 2022-9-24 08:39:16 | 显示全部楼层
学习 发表于 2022-9-23 19:53
怎样解决这错误?
上面我贴上配置了 用mqtt弄好的  4个逻辑 单击 双击 长按 松开
 楼主| 发表于 2022-9-24 08:41:20 | 显示全部楼层
怎样解决这错误?
发表于 2022-9-24 09:49:56 | 显示全部楼层
直接复制过去用不了的,那段配置是我的使用场景,需要自定义一些变量比如${node_id}等 ,对照我的单击、双击、长按等实现方式,改成你的配置文件。
GMT+8, 2025-10-20 13:57 , Processed in 0.063353 second(s), 11 queries , MemCached On.
