查看: 3362|回复: 0
[技术探讨] 好人看看这是怎么回事儿
发表于 2022-9-20 17:28:44 | 显示全部楼层 |阅读模式
armbian装的esphome然后每次编译下载esp32都出来这些个黄色的东西
/root/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c: In function 'spiTransferBytesNL':/root/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c:922:39: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]                 uint8_t * last_out8 = &result[c_longs-1];                                       ^/root/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c:923:40: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]                 uint8_t * last_data8 = &last_data;                                        ^
GMT+8, 2026-1-18 11:47 , Processed in 0.212377 second(s), 6 queries , MemCached On.
