查看: 2967|回复: 2
[技术探讨] 求一个小米电视的红外码
发表于 2022-9-18 00:34:46 | 显示全部楼层 |阅读模式
家里的小米电视遥控器看了是蓝牙遥控,不是红外的,最近入手了博联的rm4c mini,接入了ha但是貌似没法学码,求大佬指点下,分享下遥控红外码
发表于 2022-9-29 16:47:16 | 显示全部楼层
我分享下我的小米电视2的红外码供楼主参考
switch:
  - platform: broadlink
    mac: XX:XX:XX:XX:XX:XX
    # timeout: 15
    # retry: 5
    switches:
      - name: tv on/off
        command_on:  JgA0ACETFBQVMBQvFxIULxQUFS4VFhIzEzAUAAFfJRETFBMvFTAUExQvFRMVMBMTFC8VLxYADQUAAAAA=
        command_off: JgA0ACETFBQVMBQvFxIULxQUFS4VFhIzEzAUAAFfJRETFBMvFTAUExQvFRMVMBMTFC8VLxYADQUAAAAA=
      - name: tv select/ok
        command_on:  JgBKAAoADFEIAAOOCToHAAGaCQABHyETFCUWEhQiFCUUExQTFC8VHxITFC8VAAGaIxIUJRUTFB4UJRQTFBMULxUdFBMUMBUABEIHAA0FAAAAAAAAAAAAAAAAAAA=
        command_off: JgBKAAoADFEIAAOOCToHAAGaCQABHyETFCUWEhQiFCUUExQTFC8VHxITFC8VAAGaIxIUJRUTFB4UJRQTFBMULxUdFBMUMBUABEIHAA0FAAAAAAAAAAAAAAAAAAA=
      - name: tv up
        command_on:  JgBAAAiqCQABlAiVIhQTJRYTEx8SJRUTFBQTHRYcFCcTLxUAAZwhFBMmFBIVHRQmFBMUFBMdFB0UJRUwFAAFpAgADQUAAAAAAAAAAA==
        command_off: JgBAAAiqCQABlAiVIhQTJRYTEx8SJRUTFBQTHRYcFCcTLxUAAZwhFBMmFBIVHRQmFBMUFBMdFB0UJRUwFAAFpAgADQUAAAAAAAAAAA==
      - name: tv down
        command_on:  JgA8AAjSCQABjwpaIhQTJhYSFB0UJRUUFBQTHhMnFCUVFRIAAa0iExQmFBMUHRQmFRQTFBMeEyUVJRUUEwANBQAAAAAAAAAAAAAAAA==
        command_off: JgA8AAjSCQABjwpaIhQTJhYSFB0UJRUUFBQTHhMnFCUVFRIAAa0iExQmFBMUHRQmFRQTFBMeEyUVJRUUEwANBQAAAAAAAAAAAAAAAA==
      - name: tv left
        command_on:  JgA4ACEUEyUVFBMdFCYUExUTFCUWLhUdFB0UAAGaIxMTJRUTFB4UJRQTFBUSJRUxEx0UHhMAAfAHAA0F
        command_off: JgA4ACEUEyUVFBMdFCYUExUTFCUWLhUdFB0UAAGaIxMTJRUTFB4UJRQTFBUSJRUxEx0UHhMAAfAHAA0F
      - name: tv right
        command_on:  JgBAAAcABxcJAALkJBQTJhQTFB0WJBgVEhMUMBQUFBMTJRUAAa0jFRUlFRIUHRQmFBQTExQwFBQTFBMlFQAEbAkADQUAAAAAAAAAAA==
        command_off: JgBAAAcABxcJAALkJBQTJhQTFB0WJBgVEhMUMBQUFBMTJRUAAa0jFRUlFRIUHRQmFBQTExQwFBQTFBMlFQAEbAkADQUAAAAAAAAAAA==
      - name: tv back
        command_on:  JgCcACQSFUIVExYeEyQXEhQTFBwWLR0jFxwVAAGSJREXJBUSFhsVIxcTFBIVHBQuFiUWHBUAAZIlEhQkFxIVGxUkFhIWEhUbFS4WJRYbGAABlCMSFSQWEhUdFSQVEhYSFB0ULRcjFxwUAAGUJRIVJBcRFRsWJRURGBEWGhYtFiQWHRQAAZUjEhckFRIVGxYlFRMUEhUbFi4VJRYbFQANBQAAAAAAAAAAAAAAAA==
        command_off: JgCcACQSFUIVExYeEyQXEhQTFBwWLR0jFxwVAAGSJREXJBUSFhsVIxcTFBIVHBQuFiUWHBUAAZIlEhQkFxIVGxUkFhIWEhUbFS4WJRYbGAABlCMSFSQWEhUdFSQVEhYSFB0ULRcjFxwUAAGUJRIVJBcRFRsWJRURGBEWGhYtFiQWHRQAAZUjEhckFRIVGxYlFRMUEhUbFi4VJRYbFQANBQAAAAAAAAAAAAAAAA==
      - name: tv home
        command_on:  JgBAAAlnCRQIAAJzIRMUJRYSFB4TJRUUExMYJhQTFR0WJjUAAawlEBUlFRMUHxImFRMVExMmFBIVHRQmFAAERQgADQUAAAAAAAAAAA==
        command_off: JgBAAAlnCRQIAAJzIRMUJRYSFB4TJRUUExMYJhQTFR0WJjUAAawlEBUlFRMUHxImFRMVExMmFBIVHRQmFAAERQgADQUAAAAAAAAAAA==
      - name: tv menu
        command_on:  JgBMAAi7BwABlAh+IhMUJhUUEh8SJRUVFBEVHhQSFCYUJhQAAa0jFxMmFBMUHhMlFRQVEhQgExQTJRYlFAAE+wcAAk4IAAGACAACogkADQUAAAAAAAAAAAAAAAA=
        command_off: JgBMAAi7BwABlAh+IhMUJhUUEh8SJRUVFBEVHhQSFCYUJhQAAa0jFxMmFBMUHhMlFRQVEhQgExQTJRYlFAAE+wcAAk4IAAGACAACogkADQUAAAAAAAAAAAAAAAA=
      - name: tv volumedown
        command_on:  JgA6AAj0CAAB/SUUEyUVFRMdEyYUExQUFC8UMRMTFB4UAAGZIhIVJhQUEx0VJBUSFRMVMBUvFBMUHRQADQUAAAAAAAAAAAAAAAAAAA==
        command_off: JgA6AAj0CAAB/SUUEyUVFRMdEyYUExQUFC8UMRMTFB4UAAGZIhIVJhQUEx0VJBUSFRMVMBUvFBMUHRQADQUAAAAAAAAAAAAAAAAAAA==
      - name: tv volumeup
        command_on:  JgBEAAcAAVwIAAFJCCgiExUlFRMUHRMnExMUFBQuFyMVFBMVEwABrCISFSUWExMfEiUVExUTEy4iJRYTExMUAAZ4CA0PAA0FAAAAAA==
        command_off: JgBEAAcAAVwIAAFJCCgiExUlFRMUHRMnExMUFBQuFyMVFBMVEwABrCISFSUWExMfEiUVExUTEy4iJRYTExMUAAZ4CA0PAA0FAAAAAA==
    # - name: tv mute
    #   command_on: JgBCAgoAAzcjExQjFhIUGxUjFhQTExQtFSwWEhUbFAABmyQRFyMVERUcFyIVEhUSFC0WLBYSFBwVAAGaJBEWIxYSFBsVIxYTFBIULBgsFRIUGxVQCQABQiQRFyMVERscFSIWEhYRFCwXLBYSFBwUAAGbJREVIhcSFBsWIxYQFxEULBgrFhEVGxYAAZwjERYkFREVGxYjFREWEhQtFi4UERUcFAABmyUQFiIYERQbFiIWERYRFS0WLRUSFRoVAAGfJREVIxcRFBsVIxYSFhAWLBYsFhIVGhYAAZskEhUjFxEUHBQkFRMUERUsFy0WERUaFwABmyQRFiIXERQbFSMWEhURFiwXLBUSFRoXAAGZJRAXIxURFhsVIhYTFBEVLBcsFhEWGhcAAZklEBciFhEWGhUlFREVERYsFiwXERQbFQABmyQTFSIXERUbFSQVERYRFSwXLBcRFB0TAAGbJBMWIhYRFRsVJBUSFREVLhUsFhEVHBQAAZ4jEhUjFhEVGxUjFhMVERQsFywXEhUaFwABmSQRFiQVERUcFCMWExURFCwXLBYRFxkWAAGbJRMUJBYSFBsVIxcRFhAVLRYsFxIUGhYAAZolERZIFhEWGxUiGBEUERUtFiwWEhUdEwABmiQSFSQWEhUaFyYVEBYRFi0VLBcSFBsVAAGaJREWIhYRFhsUJBcQFRIULhUsFxIUGxUAAZwlEhYjFhAWGhYkFRMTEhUsFiwXEhQbFQABmiQSFiIXERUaFiMXEBUSFSwWLBchFhoVAA0FFywVEhUa
 楼主| 发表于 2022-10-2 21:17:11 | 显示全部楼层
谢谢了,帮了我大忙了
GMT+8, 2026-1-18 09:49 , Processed in 0.328956 second(s), 8 queries , MemCached On.
