楼主 |
发表于 2022-10-2 09:42:44
显示全部楼层
[{"id":"de69488b6d87aa04","type":"server-state-changed","z":"ea487c657ed40df9","name":"微软tts","server":"9f12f038.c14df","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_text.sonos_tts","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":50,"y":540,"wires":[["9d8d7e66d69a41b2"]]},{"id":"9eb0313cd99d475f","type":"api-call-service","z":"ea487c657ed40df9","name":"Sones_Edge_TTS","server":"9f12f038.c14df","version":5,"debugenabled":false,"domain":"tts","service":"edge_tts_say","areaId":[],"deviceId":[],"entityId":["media_player.duo_mei_ti_shi"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":430,"y":520,"wires":[[]]},{"id":"9d8d7e66d69a41b2","type":"function","z":"ea487c657ed40df9","name":"","func":"var a = msg.payload\nvar b = {\n data: {\n \"message\": a,\n\n }\n}\nmsg.payload = b\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":230,"y":520,"wires":[["9eb0313cd99d475f"]]},{"id":"9f12f038.c14df","type":"server","name":"Home Assistant","version":4,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m"}] |
