查看: 3160|回复: 1
[求助] Mosquitto broker升级失败
发表于 2022-9-2 07:31:19 | 显示全部楼层 |阅读模式
            Installed version6.1.2
Latest version6.1.3
群晖VMM虚拟机安装,web页面点击mosquitto升级,系统错误提示如下:
Can't install homeassistant/amd64-addon-mosquitto:6.1.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=6.1.3&fromImage=homeassistant%2Famd64-addon-mosquitto&platform=linux%2Famd64: Internal Server Error ("Get "https://registry-1.docker.io/v2/": EOF")
Can't install homeassistant/amd64-addon-mosquitto:6.1.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=6.1.3&fromImage=homeassistant%2Famd64-addon-mosquitto&platform=linux%2Famd64: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: TLS handshake timeout")
网络科学一切正常,科学模式设置为全局模式,还是无用。
 楼主| 发表于 2022-9-2 17:18:06 来自手机 | 显示全部楼层
换了不同科学服务器,全局模式,最后终于搞定了。看来对于科学稳定性还是有要求的。
GMT+8, 2025-12-20 18:41 , Processed in 0.086694 second(s), 9 queries , MemCached On.
