查看: 5440|回复: 9
[技术探讨] 【蓝图之上】用Python在HA里编写重复性高且容易维护的代码
发表于 2022-8-29 19:34:28 | 显示全部楼层 |阅读模式
之前在论坛里讨论了一下如何更好的维护自动化代码,各位大神支招后我尝试了一种用python代替蓝图的自动化的方法。好处就是可以写一个房间的package模板,然后直接生成每个房间的yaml文件。这样的话减少了代码的重复性,也比蓝图好测试很多,而且不单单只有自动化模板,其他的各种sensor的模板也可以加进去。python比yaml+jinja灵活很多,加上网上python的资料多,要做个什么搜一搜就出来了。
举个例子,因为yaml和json基本等价,可以把现有的yaml自动化转成json格式,而又因为python的语法和json一样,所以可以直接使用。yaml转成json可以直接使用我的这个小程序 https://github.com/relliky/Tais_ ... ert_yaml_to_json.py
转换后可以把json的自动化里面需要根据每个房间不同的配置的部分改成变量。然后直接自动导出成yaml就好。举个简单的自动化例子:
        "alias":"LB-" + self.automation_room_name + "Remote Button - Double - Toggle Lamps",
        "trigger": [
            "platform": "state",
            "entity_id": self.xiaomi_buttons,
            "to": "double"
        "action": [
            self.turn(self.lamps, "toggle"),
上面的turn函数是我自己定义的,减少代码量去不去写 service:light.turn on, entity_id: self.lamps
再举一个复杂一点的例子:
    self.automations += [{
        "alias" : "LB-" + self.automation_room_name + "Remote Button - Single - Toggle Bed Lights/Ceiling Lights",
        "trigger": [
            "to": "single"
        "mode":"queued",
        "action": [
            "choose": [
            # State Machine
            # "All White" ->  "Lamp LED White" -> "LED White"
            # -> "Hue" -> "Night Mode" ->  "Dark Night Mode"
            # -> "All Off"
                "conditions": [
                    "condition": "state",
                    "entity_id": self.ceiling_lights + self.lamps + self.leds,
                    "state": "off"
                "sequence": self.setSceneService("All White")
              #  Default Room support these scenes
              self.ifOldSceneSetNewScene("All White",       "Lamp LED White"),
              self.ifOldSceneSetNewScene("Lamp LED White",  "LED White")
              # Master Room supports a few more scenes
              self.ifOldSceneSetNewScene("LED White",       "Hue"),
              self.ifOldSceneSetNewScene("Hue",             "Night Mode"),
              self.ifOldSceneSetNewScene("Night Mode",      "Dark Night Mode"),
              self.ifOldSceneSetNewScene("Dark Night Mode", "All Off")
            ] if self.room_entity == 'master_room' else [
              # Default Room does not support extra scenes
              self.ifOldSceneSetNewScene("LED White",       "All Off")
  def ifOldSceneSetNewScene (self, old_scene, new_scene):
    cond_seq = {
        "conditions": [
            "entity_id": "input_select." + self.room_scene,
            "state": old_scene
        "sequence": [
           { "service": "input_select.select_option",
             "target": {
             "data":{
               "option": new_scene
           { "service": "homeassistant.turn_on",
              "entity_id": "scene." + self.room_entity + new_scene }
    return cond_seq
以上是个状态机。因为python语言的灵活性,不像yaml只能把script放在冒号后,python可以把任何函数放在几乎任何地方。python的函数也比script要灵活很多比如choose里面调用condition-sequence对,这样的话,我就不用把 ifOldSceneSetNewScene 这段代码调用的部分复制粘贴很多遍。
现有的我的完整python文件在这里:https://github.com/relliky/Tais_ ... /gen_config_yaml.py  生成的yaml文件在这里:https://github.com/relliky/Tais_ ... _generated_packages    以后还会迁移更多的东西进这个python代码。
因为我的几个房间自动化几乎一致,变成这样以后比蓝图还是灵活很多。
发表于 2022-8-30 09:45:31 | 显示全部楼层
作为一个小白,我觉得json比yaml好,也容易懂。感谢大佬分享
发表于 2022-8-30 09:50:01 | 显示全部楼层
 楼主| 发表于 2022-8-30 15:24:31 | 显示全部楼层
看来你比较熟悉json。json的语法还是繁冗些,yaml是很多地方用空格代替了json的括号。不过两个基本都是等价的。
发表于 2022-8-31 07:23:26 | 显示全部楼层
relliky 发表于 2022-8-30 15:24
看来你比较熟悉json。json的语法还是繁冗些,yaml是很多地方用空格代替了json的括号。不过两个基本都是等 ...
我刚开始学,json比较习惯,我再好好学学yaml,谢谢大佬
发表于 2023-4-21 20:16:02 | 显示全部楼层
值得学习
发表于 2023-7-4 18:54:01 | 显示全部楼层
你好 不错!!!!!!!!!!!!!!!
发表于 2024-12-10 13:25:42 | 显示全部楼层
发表于 2025-7-2 18:42:24 | 显示全部楼层
发表于 2025-9-6 21:43:01 | 显示全部楼层
测试测试
GMT+8, 2026-1-31 01:51 , Processed in 0.056212 second(s), 12 queries , MemCached On.
