查看: 11384|回复: 22
博联Pro 控制 至高空调
发表于 2017-11-18 20:36:08 | 显示全部楼层 |阅读模式
# 分组分页
#group:
default_view:
  view: yes
  icon: mdi:home
  entities:
    - group.airconditioner_control
select_rooms_ac:
  icon: mdi:air-conditioner
  initial: "服务机房"
  options:
    - 服务机房
    - VIP-1房
    - VIP-2房
    - VIP-3房
    - VIP-4房
    - VIP-5房
    - VIP-6房
select_mode_ac:
  icon: mdi:settings
  initial: "制冷模式"
  options:
    - 关闭空调
    - 自动模式
    - 制冷模式
    - 除湿模式
    - 制热模式
    - 通风模式
airconditioner_temp:
  icon: mdi:thermometer-lines
  initial: "24"
  options:
    - 16
    - 17
    - 18
    - 19
    - 20
    - 21
    - 22
    - 23
    - 24
    - 25
    - 26
    - 27
    - 28
    - 29
    - 30
    - 31
    - 32
airconditioner_volume:
  icon: mdi:weather-windy
  initial: "中风模式"
  options:
    - 小风模式
    - 中风模式
    - 大风模式
airconditioner_control:
  view: no
  control: hidden
  entities:
    - input_select.select_rooms_ac
    - input_select.select_mode_ac
    - input_select.airconditioner_volume
    - input_select.airconditioner_temp
# 自动化
- alias: mode_ac
  initial_state: true
  hide_entity: true
  trigger:
    platform: state
    entity_id: input_select.select_mode_ac
  action:
    - service: script.turn_on
      data_template:
        entity_id: >
          {% if is_state("input_select.select_mode_ac", "关闭空调") %} script.acoff
          {% elif is_state("input_select.select_mode_ac", "自动模式") %} script.automatic
          {% elif is_state("input_select.select_mode_ac", "制冷模式") %} script.refrigeration
          {% elif is_state("input_select.select_mode_ac", "除湿模式") %} script.dehumidification
          {% elif is_state("input_select.select_mode_ac", "制热模式") %} script.heating
          {% elif is_state("input_select.select_mode_ac", "通风模式") %} script.aeration
          {% endif %}
- alias: temperature_no
  initial_state: true
  hide_entity: true
  trigger:
    platform: state
    entity_id: input_select.airconditioner_temp
  action:
      data_template:
        entity_id: >
          {% if is_state("input_select.airconditioner_temp", "16") %} script.temp16
          {% elif is_state("input_select.airconditioner_temp", "17") %} script.temp17
          {% elif is_state("input_select.airconditioner_temp", "18") %} script.temp18
          {% elif is_state("input_select.airconditioner_temp", "19") %} script.temp19
          {% elif is_state("input_select.airconditioner_temp", "20") %} script.temp20
          {% elif is_state("input_select.airconditioner_temp", "21") %} script.temp21
          {% elif is_state("input_select.airconditioner_temp", "22") %} script.temp22
          {% elif is_state("input_select.airconditioner_temp", "23") %} script.temp23
          {% elif is_state("input_select.airconditioner_temp", "24") %} script.temp24
          {% elif is_state("input_select.airconditioner_temp", "25") %} script.temp25
          {% elif is_state("input_select.airconditioner_temp", "26") %} script.temp26
          {% elif is_state("input_select.airconditioner_temp", "27") %} script.temp27
          {% elif is_state("input_select.airconditioner_temp", "28") %} script.temp28
          {% elif is_state("input_select.airconditioner_temp", "29") %} script.temp29
          {% elif is_state("input_select.airconditioner_temp", "30") %} script.temp30
          {% elif is_state("input_select.airconditioner_temp", "31") %} script.temp31
          {% elif is_state("input_select.airconditioner_temp", "32") %} script.temp32
          {% endif %}
- alias: volume_ac
  initial_state: true
  hide_entity: true
  trigger:
    platform: state
    entity_id: input_select.airconditioner_volume
  action:
      data_template:
        entity_id: >
          {% if is_state("input_select.airconditioner_volume", "小风模式") %} script.breeze
          {% elif is_state("input_select.airconditioner_volume", "中风模式") %} script.apoplexy
          {% elif is_state("input_select.airconditioner_volume", "大风模式") %} script.gale
          {% endif %}
acoff:
    sequence:
      - service_template: >
          {% if is_state("input_select.select_rooms_ac", "服务机房") %}
            broadlink.send_packet_192_168_19_250
          {% elif is_state("input_select.select_rooms_ac", "VIP-1房") %}
            broadlink.send_packet_192_168_19_249
          {% elif is_state("input_select.select_rooms_ac", "VIP-2房") %}
            broadlink.send_packet_192_168_19_248
          {% elif is_state("input_select.select_rooms_ac", "VIP-3房") %}
            broadlink.send_packet_192_168_19_247
          {% elif is_state("input_select.select_rooms_ac", "VIP-4房") %}
            broadlink.send_packet_192_168_19_246
          {% elif is_state("input_select.select_rooms_ac", "VIP-5房") %}
            broadlink.send_packet_192_168_19_245
          {% elif is_state("input_select.select_rooms_ac", "VIP-6房") %}
            broadlink.send_packet_192_168_19_244
          {% endif %}
        data:
          packet:
            - "JgDIAMjyEjYSNhI2EjYSNhI2EjYSNxEUERQRExMTEhMRFBEUEhQRNRM2EjYRNxE3EjYSNhM1EhMSFBEUEBQSExIUERQRFBE2ETcSNhI3ETYSNhM1EjYSExMUERQQFBEUERMTFBEUEDcRNxIUEDcSNhIUERQQNxIUEBURNhEUEhQRNhI2EhQRNhIUETYSFBE2EhQRNxE2ExQQNhMUEDcSFBA3EhQQFBEUEjYRFBI2EhQRNhIUERQRNhIUETYSFBE2EhQRNhI2EvQSAA0F"
breeze:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMfzEjcRNhI2ETcSNhI2EjYSNhITEhQRExITEhMSFBEUERMSNxE3EjUTNRM1EjcRNxI3ERMSExEUEhMSExITEhMRFBITEjYSExI2EjYSNhI2EjYSNhIUETcRFBETEhMSExMTEjUTExITETcSNhI2EhMSNhITEjYSNhITEhMSExI2EhMSNhI2EjYSExI2EhMSNxE2EhUQFBETEjYSExI3ERMSExMSEzUTExI2EhMSNhITEhMSNhITEjYSExI2EhMSNhI2EvMSAA0F"
apoplexy:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb0ETcPORA4ETcRNxA4ETcROBAVEBQRFBAVEBYQFRAVEBUQOBE3ETYQORA4ETcRNw85ERQPFg8WERQRFBEUERQPFhAVETgOFhE3DzkRNxE4EDcQOBEUEDgRFBAWDxYRFBAVEDgRFBAVEDgRNxE3DxYQOA8WEDgPOREUDxYPFhA4DxcPOBA4ETcRFBE3ERQROBA4DxYQFRAUETgQFRA4ERQQFRAUEDkQFRA4ERQQOBEUEBUPOREUDzkRFBA4ERQRNxE3EfQQAA0F"
gale:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMfzEDgRNxE3DzkRNxE3ETcQOBEUEBUQFg8WEBQRFBEUEBUQOBE4EDgRNhA5DzkRNxE3DxYRFBEUERQQFQ8WDxYRFBEUETcRFBE3ETgOORE3ETcRNxAWDzgQFg8WEBUQFBEUEDgRFBEUEDkQOBEUEDgRNxAVETcQOA8WDxYQOA8WEBURNw85EDgRFBE3ERQRNxM2EBUQFBEUETcRFBE4EBQRFBEUEDkQFBA5EBUPOREUEBUPORAVDzkRFA85ERQPORE3EfUPAA0F"
automatic:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb0EDgQOBA4EDgROBE3DzgQOBAWDxYRFBEUDxUQFhEUERQPORE3EjYRNxA4DzkPORI2ERQQFQ8WEBURFBITEBYPFREUEDgROBE3DzgQOBI2EjcRNxEUERQPFg8WERQRFA8WDzkPFg85DxYQOA8WEBURNxEUETcRFBE3ERQQOBE3ERQRFBA4EjYRFBA4EjcRNxE3EDcQFhAVETcQFREUDxYPFhAVETcRFBE3ERQRNxEUERQPORAVDzkRFA85EBUPORA4EPQSAA0F"
refrigeration:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb0ETgRNw84EDgQOBE4ETcRNw8WERQRFA8VEBYRFBEUDxYPOQ85EjYRNxE3EDgPORA4EhMQFQ8XEBQRFBAWDxYPFREUETcROBE3DzgQOBA5ETcRNxEUERQPFg8WEBURFA8WDzkRFA85DxYPOQ8WDxYRNxAVETcQFRE3ERQRNxE4ERQQFBA4ETgRFBA4ERQPORE3ETcQFREUETcRFA85ERQPFg8WETcQFRE3EBURNxEUERQQOBEUEDgRFBA4EhMQOBA4EfEUAA0F"
dehumidification:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb0EDgPORA4ETcRNxE4DzkPOBAWDxYQFBAVEBYQFRAVEBQQORA4ETcQOBA4DzkPORA4ERQPFw4WEBURFBAVDxYQFREUETcQOBA5DzgQOBA4EDgROBETERQSExAWEBURFA8VEDkPFg85DxYQOA8WEBURNxAVETcRFBE3ERQRNxE3EBURFBA4ETcRFBA4ETcRFBA4ETgPFhAUEDgRFBAVEDgQFhAVETcQFRE3EBURNxEUERQPOREUDzkQFQ85EBYOORA4EfQRAA0F"
heating:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb1EzUSNhI2EDgPOQ85EjYSNhITEhMRFQ4WEBUSExEUDxcQNw85EDgSNhM2EjYPOQ84EBYPFhITEhMRExAWEhMSEw8WDzkPORE3EjYSNhE3DzkPOREUDxYQFRITERQQFg8VEzYPFRM2ERMTNRMSExIQOBEUEDgRFBA4EBYPOQ85EhMPFhE3DzkPFhA4DzkPORITDzkQFQ8WEDgPFhMSExIQOBMSEDgTEhA4EhMQOBAWDxYSNg8WEjYSExI2EhMSNhI2EvMQAA0F"
aeration:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb0EDgPOQ85EjYRNxE4DzgQOBEVDxYPFREUEBUQFg8WEBQROBE3ETcQNxA5ETcPORE3ERQRFA8WDxYQFREUDxYPFhAVETcRNxA4DzkQOBE3ETgPOQ8WEBQRFBAVEBYRFBAUEDgSFA85ERMQOQ8WDxYQNxAWEDgPFhE3EBURNxA4DxYQFRE3ETcQFRE3ERQRFBA4ETcRFBEUEDgQFRA4EDgQFRAVEDgQFg84EBYQNxAWERQRNxEUETcRFBA4ERQQOBE3EfQQAA0F"
ac_off:
    sequence:
          {% endif %}
        data:
          packet:
temp16:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMjyEjYPOQ85ETcSNhI3DzgQOBAVEBYRFBISERQQFg8WEhMSNhI2EDcQOQ85EjYSNhE3DxYSExITEBUPFg8WEhMSExAVDxYQOA85EDgRNxI3ETYQOBA4ExIQFg8WEhMSEhAVEDkPFRA5DxYPOQ8VEBYSNg8WEjYPFhE3DxYSNhA4DxYPOQ85EDgSNhI3DxYRNw84EBYPFhISERQQFRA4EBYPFhITEjYSExI2EhMSNhITEhMPORITDzkSEw85EhMPORI2EvMRAA0F"
temp17:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMnyEjYRNxI3ETYSNhE3EjYSNhIUERMSExITEhMSFBEUERMSNxE3EjUTNRI3ETcSNhI2EhMSExITEhMRFBEUEhMSExI2EhMSNhI2EjYRNxI2EjYSFBE2EhQRExITEhMSExMTETYSFRE1ExITNRMSExMSNhITEjYSExI2EhQRNhI2ERQSFBE2EjYRNxI2EhMSNhI2EjYSExIVEBQRExI3ERQRExITEzUSExI2EhQRNxEUERQSNhEUEjYRFBI2ERQSNhE3EvMSAA0F"
temp18:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMfzEDgQOBA4EjYSNhA4EDgQOQ8VEBUQFRAWDxYPFRAVEBUQOBA5DzkQOBE2EDkPORA4EBUQFQ8WDxYQFRAVEBUPFg85DxcOOQ85EDgQOBA4EjYSFBE2EBYPFg8VEBUQFRAWDzgQFg84EhQQNxIUEBUQOBAVEDgQFRA4EBUQOBA4EhMQOBITEDgSNhI2EBUSNhA4EBUSNhAVEhMQFg84EBYPFg8VEDkPFg85EBUPORAVDxYPOQ8WDzkQFQ85EBUSNhA4EPUQAA0F"
temp19:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb0DzkQOBA4EDgPOQ85EDgQOBAVEBUQFRAVEhMQFRAVEBUQOBA4EDkPOQ84EDgQOQ85EBUQFQ8WDxYQFRAVEBUPFg85DxYPOQ85EDgQOBA4DzkQFQ85ERQPFhAVEBUQFRAVEjYQFRA4EBYRNhAWERQQNxIUEDgRFBA4ERQQOBA4DxYQFRAVEDgQOBE3DxYQOBI2EDgQOBAVEBUSExA4EhMQFg8WDzkPFg85EBUPORAVDxYPOQ8WDzkQFQ85EBUPORA4EPUSAA0F"
temp20:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMfzEjcPORA4EDgQOBI2DzkQOBAVEBUQFRITEBUQFRAVEBYPOBA4EjYQOQ85DzgQOBA5DxYPFRAWEBUQFQ8WDxYPFhA4ERQQOBE3DzkQOBA4EDgSExA5DxUQFRAVEBUQFg8VEDkPFRA5DxYPORAVDxYPOQ8WDzkQFQ85EBUPORA4EBUQOBA4ERQQOBI2EhMQOA85EBUPFhA4EBYPFRA5DxUQFRAVEDgQFRA4EBUQOBAVEBYQNxAWETYSFBA4DxYQOA85EfQQAA0F"
temp21:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb0DzkSNhI2EjYPOQ85EjYTNREUExITEhAWDxYRExMSEhMQOBE4EjYSNg84EDkQOBI2EhMSExEUDxYPFhITEhMPFg85DxYPORE3EjYTNRI2DzkQFRA4EBUQFg8VExITEhAWDzgQFRA4EBYPOBAWDxYSNg8WETYQFhI2EBUSNhA4DxYQFRI2EBUSNhA4DxYRNw85EDgSExA4EhMQFRA4EBYPFhEUEjYSExI2EhMSNhEUERQPORITDzkSEw85EhMPORI2EvIPAA0F"
temp22:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMX1EDgPOQ85EDgQOBA5DzgQOBAVEhMQFg8WDxUQFRAVEBYPOBA4EDkPORA4ETYQOQ85EBURFA8WEBUQFRAVDxYSExA4DxYQOA85ETcQOBA5DzgQFg84EhQRFA8VEBUQFRAWDzgQFhA3EBYQNxAWEBUQOBAVEDgQFRA4EBUQOBA4DxYQOA8WEBUQOBA4DxYQOA85EBUQOBA4EBUSExA4EBUQFhAVDzkQFRA4EBUQOBAVEBUPORAVDzkQFRA4EBUQOBA4EPYRAA0F"
temp23:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMX1EDgSNg85EDgQORE2EDgQOBAVEBUQFRIUDxYPFRAVEBUQOBA5DzkQOBE2EDkPORA4EBUQFRAVDxYSExAVEBUQFQ85EBUPORA4EDgQOBI2EDgQFRA4EBUQFRAWERQPFg8VEDkPFg85DxYPORAVDxYPOQ8WDzkQFQ85EBUPORA4EBUQFREUDxYQOA85EBUPORA4EDgQORE2EhQRFA85ERQQFQ8WDzkPFg85EBUPORAVDxYPORAVDzkQFQ85EBUPORA4EPUQAA0F"
temp24:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMfzDzkQOBA4EDgPORA4EDgQORETEBUQFRAVEBUSFA8VEBUQOBA5DzkRNhA4EDkPORA3EhQQFRAVDxYPFRIUEBUQFQ85EBUQOBA4EDgSNg85EDgQFRA4EBUQFRAVEhQPFRAVEDgQFRA5DxUQOQ8WDxUQOQ8WDzkPFg85DxYPORA4EBUQOBA4EDgPFhA4EhMQOBI2EBUSExAVEDgQFRA5DxUQFRAVEDgQFRA4EBUQOBAVEBYRNhAWETcPFhE3DxYRNw85EPUQAA0F"
temp25:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMfzEDkPORA4EDcQOQ85EDgQOBAVEBUQFQ8WDxYQFRAVEBUPORE3EDgQOQ45EDgRNxA5DxYPFRAVEBYPFhAVDxYPFg85DxYPORE3EDgQOBA4DzkQFQ85EBUPFhAVEBUQFRAVDzkQFRA4EBUQOBAVEBYPOBAWDzgQFhA3EBYQNxA4EBUQFhA4DzkPFg85ERQPOQ85EDgQFRAVDzkQFQ85EBUQFg4WEDgQFg84EBYPOQ8WDxYPORAVDzkQFQ85EBUPORA4EPUSAA0F"
temp26:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb0EDgQORE3EDgPORE3EDgQOBAVEBUQFQ8WDxYQFRAVEBUPORA4EDgQOA85EDgQOBA5DxYPFRAVEBUQFg8WDxUQFRA4EBUQORA4EDgQOA85DzkRFA85EBUPFg8WEBUQFRAVDzkQFQ85EBUQOBAVERUOORAVEjYQFRA4EBYPOBA4ERQQOBEUEDkPFg85DxYPOQ85EBUPORAVDzkQFRA4EBUQFQ8WDzkPFg85DxcPOBAWDxYPOQ8WDzkPFg85DxYPOQ84EPYPAA0F"
temp27:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb0EDgPORA4EDgQOQ84EDgQOBAVEBYPFhAVDxYPFRAVEhQQNxI3DzkRNxA4EDgQOA85EBUPFhAVEBUQFRAWDhYQFRA4EBUQOQ85ETYQOBE3EDkQFQ85EBUPFg8VEBYQFRAVEDgQFRA4EBUQOBAVEBUPORAVDzkQFQ85EBUPORE3EBUQFRAWDjkQFg45EBYPOBA4EDgQORAVDzkQFQ85EBUQFREUDzkPFg85DxYPOREUDxYQOA8WEDgPFhA4EBUQOBI2EPQRAA0F"
temp28:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMX1EDgQOBA4DzkPORA4EDgQOBAWDxUQFRAVEBYPFg8WDxUQOBA5EDgPOBA5DzkQOBA4EBUQFRAVDxYPFhAVEBUQFQ85EBUPORA4EDgQOQ45EDgRFBA4ERQQFg8WDxUQFRAVEDgQFRA4EBUQOQ8VEBYQNxAWEDgPFhA4DxYQOBA4DxYQOA85EBUPFhA4DxYQOA85EBUQFg84EDgQFg84EBYPFhAVDzkQFQ85EBUPORAVDxYPORAVDzkQFQ85EBUPORA4EPISAA0F"
temp29:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMX1DzkPOBA4ETgPORA3EDkPOQ8WDxUQFhAVEBUPFg8WERQQOBE3DzkRNxA4EDgQOBA4EBUQFg4WEBUQFRAVEBYPFg85DxYPORA3EDgQOQ85EDgQFRA4EBUQFRAVDxYPFhAVEDgQFRA4EBUQOBAVEBUQOBAVEjYQFRE3EBUQOBA5DxUQFRA4EBUQFRA4EBUQOQ85DzkQFRA4EDgQFRA4EBUQFRAVDzkRFA85ERQPORAVDxcPOBAWDzgSFA45EBYPOBA4EvQPAA0F"
temp30:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb0EjYQOBA4EDkPOQ84EDgROA8WDxYPFRAWEBUQFQ8WDxYQOA85EDgQOBA4EDgPORE3EBUQFQ8WEBUQFRAVERQQFg84EBYPOBA4EDgQOQ85EDcSFBA4DxYQFRAVDxYPFg8WEDgQFRA4EBUQOBAVEBUQOBAVEDgQFRE3EBURNxA4EBUQOQ8VEBUQFRA4ERQQOBA5DxUSNw85EDgQFRA4EBUQFRAVDzkQFQ85EBUPORAVDxYPOQ8WDzkQFg84EBYPOBA4EvMRAA0F"
temp31:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMb0EzYPORA3EjcPOQ85EDgQOBEUEBUQFRAVDxYQFRAVEBUQOBA4EDkPOBA4EDgQOQ85DxYPFg8VEBUQFg8WEBUPFRA5DxYPOQ85EDgQOA85DzkQFQ85EBUPFg8WEBUQFRAVDzkQFRA4EBUQOBAVEBYPOBIUDzgQFg84EBYPOBA4EBUQFhAVEBUPFg85EBUPORA4EDgQOA85DzkQFQ85EBUPFw4WEDkPFRA5DxUQOQ8WDxUQOQ8VEDkPFRA5DxYPORA4EPURAA0F"
temp32:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgDIAMX1EDgPORE3EDgQOQ84EDgQOBAVEBUQFRAWDxYPFRAVEBUQOBA5DzkQOBA3EDkPORA4EBUQFQ8WDxYRFBAVEBUQFRI2EBUSNhA4EDgQOA85EDgQFRI2EBUQFRAWDxYPFRAVEDgQFRA5DxYRNw8WERQPOQ8WDzkQFRI2EBUPORA4EBUQOBA4EDgPORAVDxcPOBA4EBUQFg8VEBUQOQ85EBUPFg8WDzkPFg85DxYPORAVDxYPOQ8WDzkPFg85EBUPORA4EPUQAA0F"
 楼主| 发表于 2017-11-18 20:44:32 | 显示全部楼层
空调控制面板
空调控制面板
参与人数 1金钱 +12 收起 理由
+ 12 666!
发表于 2017-11-18 21:46:29 | 显示全部楼层
这贴够长
发表于 2017-11-19 10:37:59 | 显示全部楼层
博联出个微联版的就没这么麻烦了
发表于 2017-11-19 11:03:30 | 显示全部楼层
全是干货,点赞!
发表于 2017-11-19 12:44:32 | 显示全部楼层
配置文件就这么长。。。
发表于 2017-11-19 13:51:58 | 显示全部楼层
过来学习一下,谢谢大神!!
发表于 2017-11-19 13:59:19 | 显示全部楼层
过来学习一下,谢谢大神!!
 楼主| 发表于 2017-11-19 15:02:51 | 显示全部楼层
airconditioner_control.yaml (37.93 KB, 下载次数: 53)
automations.yaml (1.97 KB, 下载次数: 37)
sensor.yaml (440 Bytes, 下载次数: 39)
groups.yaml (557 Bytes, 下载次数: 34)
发表于 2017-12-1 01:13:29 来自手机 | 显示全部楼层
感謝分享
GMT+8, 2026-1-3 08:57 , Processed in 0.324635 second(s), 13 queries , MemCached On.
