查看: 3272|回复: 5
[已解决] ESPHome是不是不支持8266+st7735
发表于 2022-8-20 14:57:05 | 显示全部楼层 |阅读模式
esp32是可以的,但是我现在只有一个用来读小米温湿度和体重了,加入st7735代码FLASH不够用了,所以想用闲置的8266MCU
display中添加setup_priority: -100  无效
大佬们有没有用过这个屏幕的,,,,求各位指导~~~~
(´⊙ω⊙`)!
发表于 2022-9-23 15:50:53 | 显示全部楼层
你搞定没,我有一块7735,打死不显示......
spi:
  clk_pin: GPIO14
  mosi_pin: GPIO13
display:
  - platform: st7735
    model: "INITR_MINI160X80"
    reset_pin: D4
    cs_pin: D1
    dc_pin: D2
    rotation: 0
    device_width: 128
    device_height: 128
    col_start: 0
    row_start: 0
    eight_bit_color: true
    update_interval: 5s
发表于 2022-9-25 00:08:33 | 显示全部楼层
spi:
  clk_pin: GPIO14
你先试试这个?我的可以显示(esphome官网里面的例子)
spi:
  clk_pin: GPIO14
  mosi_pin: GPIO13
  miso_pin: GPIO12
display:
  - platform: st7735
    model: "INITR_18BLACKTAB"
    reset_pin: 2
    cs_pin: 5
    dc_pin: 4
    rotation: 0
    device_width: 128
    device_height: 160
    col_start: 0
    row_start: 0
    update_interval: 5s
    lambda: |-
      auto red = Color(255, 0, 0);
      auto green = Color(0, 255, 0);
      auto blue = Color(0, 0, 255);
      auto white = Color(255, 255, 255);
      it.rectangle(20, 50, 30, 30, white);
      it.rectangle(25, 55, 30, 30, red);
      it.rectangle(30, 60, 30, 30, green);
      it.rectangle(35, 65, 30, 30, blue);
发表于 2022-9-25 08:02:01 来自手机 | 显示全部楼层
谢谢,我试试
发表于 2022-9-26 14:02:34 | 显示全部楼层
楼主,可以显示了,谢谢!
font:
  - file: 'font.ttf'
    glyphs: 信息余额温度湿时间电费水卡室内状态元显示器!"%()+,-_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz
spi:
  clk_pin: GPIO14
  mosi_pin: GPIO13
display:
  - platform: st7735
    reset_pin: D4
    cs_pin: D8
    dc_pin: D3
    rotation: 0
    device_width: 128
    device_height: 128
    col_start: 0
    row_start: 0
    update_interval: 5s
    pages:
      - id: page1
        lambda: |-
          it.printf(64, 0, id(my_font), TextAlign::TOP_CENTER, "温湿度信息");
          if (id(tds).has_state()) {
            it.printf(20, 40, id(my_font), TextAlign::TOP_LEFT, "温度: %.1f", id(tds).state);
          if (id(tds1).has_state()) {
            it.printf(20, 80, id(my_font), TextAlign::TOP_LEFT, "湿度: %.1f", id(tds1).state);
  - platform: homeassistant
    entity_id: sensor.test_temperature
    internal: true
    entity_id: sensor.test_humidity
    internal: true
发表于 2022-9-26 14:05:55 | 显示全部楼层
屏边缘有花纹,不知道啥意思?
GMT+8, 2025-12-20 14:56 , Processed in 0.120575 second(s), 12 queries , MemCached On.
