查看: 5106|回复: 12
[已解决] 求七合一空气检测(SM300D2ESP32)固件
发表于 2022-8-19 17:42:35 | 显示全部楼层 |阅读模式
求SM300D2ESP32,或者ESP8266固件,希望刷入固件后接入Home Assistant
找了一些参考文件,遗憾还是没有成功:
网友的一些经历1----https://community.home-assistant ... m300d2-issue/324891
网友的一些经历2----https://blog.csdn.net/GSH_Hello_World/article/details/89886933
网友的一些经历3----https://github.com/esphome/espho ... /sensor/sm300d2.rst
官方文档----https://esphome.io/components/sensor/sm300d2.html
 楼主| 发表于 2022-8-19 20:10:58 | 显示全部楼层
自己顶一下
准备用ESP32,或者8266接入HA,求固件
发表于 2022-8-19 21:02:00 | 显示全部楼层
官方文档不是都写好了  还找什么固件?
 楼主| 发表于 2022-8-19 23:00:09 | 显示全部楼层
嘻嘻 发表于 2022-8-19 21:02
官方文档不是都写好了  还找什么固件?
贴到ESPHome,编译后,刷入8266(用的是D1mini)启动不了,所以我感觉是不是代码头文件有问题。
esphome:
  platform: ESP8266
  board: esp01_1m
#  platformio_options:
#    platform: https://github.com/platformio/platform-espressif32.git#feature/arduino-upstream
#    platform_packages:
#      - framework-arduinoespressif32@https://github.com/espressif/arduino-esp32.git#2.0.0
#    board_build.variant: esp32c3
#    board_build.f_cpu: 160000000L
#    board_build.f_flash: 40000000L
#    upload_protocol: esptool
#    board_build.flash_mode: dio
wifi:
  ssid: "WHH"
  password: "ww12345678.."
captive_portal:
logger:
api:
  password: 'es123456api'
ota:
  password: 'es123456ota'
web_server:
  port: 80
time:
  - platform: sntp
# Example configuration entry
uart:
  rx_pin: 1
  tx_pin: 3
  baud_rate: 9600
  - platform: sm300d2
    co2:
      name: "SM300D2 CO2 Value"
    formaldehyde:
      name: "SM300D2 Formaldehyde Value"
    tvoc:
      name: "SM300D2 TVOC Value"
    pm_2_5:
      name: "SM300D2 PM2.5 Value"
    pm_10_0:
      name: "SM300D2 PM10 Value"
    temperature:
      name: "SM300D2 Temperature Value"
    humidity:
      name: "SM300D2 Humidity Value"
    update_interval: 60s
 楼主| 发表于 2022-8-21 00:31:27 | 显示全部楼层
下午抽时间倒腾了一会儿,竟然读到数据了,现在把成果贴出,给有需要的同学一个参考
板子:ESP8266 nodemcu v3
代码如下:
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "WHH"
captive_portal:
logger:
api:
ota:
web_server:
  port: 80
time:
  - platform: sntp
uart:
  rx_pin: 3
  tx_pin: 1
  baud_rate: 9600
  - platform: sm300d2
    co2:
    formaldehyde:
    tvoc:
    pm_2_5:
    pm_10_0:
    temperature:
    humidity:
 楼主| 发表于 2022-10-7 21:52:57 | 显示全部楼层
放假,打了个板子,直接插在插座上还是很方便。
qqkj 手机认证
发表于 2022-10-8 21:46:58 | 显示全部楼层
楼主这个模块多少钱入的?能否PM个购买地址。
发表于 2022-10-9 15:36:13 来自手机 | 显示全部楼层
谢谢,正要买这个放家里!
 楼主| 发表于 2022-10-10 21:54:32 | 显示全部楼层
模块闲鱼100.00元买的,可以直接关键词“SM300D2”,或者“七合一空气检测”
 楼主| 发表于 2023-6-21 20:17:02 | 显示全部楼层
GMT+8, 2025-12-18 14:09 , Processed in 0.149893 second(s), 11 queries , MemCached On.
