查看: 2246|回复: 2
[求助] vi或vim命令执行没能完成
发表于 2022-8-19 16:02:04 | 显示全部楼层 |阅读模式
网上找了很多教程也没有解决到。大佬们帮下看下。就是mqtt去匿名的配置文件(目录:vi /etc/mosquitto/mosquitto.conf)
root@mqtt:/# ls
bin  boot  dev  etc  home  lib  lib64  media  mnt  opt  proc  root  run  sbin  srv  sys  tmp  usr  var
root@mqtt:/# cd etc
root@mqtt:/etc# ls
adduser.conf            default       gshadow      issue          logrotate.d     os-release  rc2.d        selinux   timezone
alternatives            deluser.conf  gshadow-     issue.net      mke2fs.conf     pam.conf    rc3.d        shadow    update-motd.d
apt                     dpkg          gss          kernel         mosquitto       pam.d       rc4.d        shadow-   xattr.conf
bash.bashrc             e2scrub.conf  host.conf    ld.so.cache    mosquitto.conf  passwd      rc5.d        shells
bindresvport.blacklist  environment   hostname     ld.so.conf     motd            passwd-     rc6.d        skel
cron.d                  fstab         hosts        ld.so.conf.d   mtab            profile     rcS.d        subgid
cron.daily              gai.conf      hosts.allow  libaudit.conf  netconfig       profile.d   resolv.conf  subuid
debconf.conf            group         hosts.deny   localtime      nsswitch.conf   rc0.d       rmt          systemd
debian_version          group-        init.d       login.defs     opt             rc1.d       security     terminfo
root@mqtt:/etc# cd mosquitto
root@mqtt:/etc/mosquitto# ls
aclfile.example  ca_certificates  certs  conf.d  mosquitto.conf  pskfile.example  pwfile.example
root@mqtt:/etc/mosquitto# vi mosquitto.conf
bash: vi: command not found
发表于 2022-8-19 22:38:58 来自手机 | 显示全部楼层
试一下nano命令
 楼主| 发表于 2022-8-20 09:29:38 | 显示全部楼层
感谢,好像还不行。
root@mqtt:/# nano /etc/mosquitto/mosquitto.conf
bash: nano: command not found
root@mqtt:/#
GMT+8, 2025-11-5 07:18 , Processed in 0.200180 second(s), 6 queries , MemCached On.
