查看: 14813|回复: 21
[经验分享] 林内燃气热水器 控制面板接入 ha
发表于 2022-8-11 11:04:24 | 显示全部楼层 |阅读模式
RT,
买的林内,比较早,不带wifi,今天拆洗,发现 控制面版与主控之间 有 4根线,第一反应应该是  uart。
面板采用的芯片采用的是mb95f564kn,https://max.book118.com/html/2021/0614/8012012111003110.shtm
TOP-20 封装。
接口从左到右,分别是 gnd  - vcc(5v) -  tx - rx
各引脚对应关系。
rx -  16pin
tx - 15pin
程序每秒发一个 查询状态命令,当查询到状态时,数码管亮,否则,不亮。
比较操蛋,上电,不恢复上一次的结果。
用esp32 调试了下 。发现下面的命令 。
# 开关 toggle
0x02,0x55,0x20,0x03,0x37,0x38,0x0D
# 温度 -
0x02,0x55,0x31,0x03,0x38,0x39,0x0D
# 温度 +
 0x02,0x55,0x30,0x03,0x38,0x38,0x0D
# echo toggle
 0x02,0x55,0x29,0x03,0x38,0x31,0x0D
# 查询状态命令
0x02,0xF6,0x30,0x34,0x38,0x30,0x30,0x33,0x03,0x32,0x38,0x0D
# 返回的数据。
0x02,0xF6,0x30,0x34,0x38,0x30,0x30,0x33,0x30,0x30,0x30,0x46,0x30,0x35,0x03,0x36,0x33,0x0D 41 摄氏度
0x02,0xF6,0x30,0x34,0x38,0x30,0x30,0x33,0x30,0x30,0x30,0x46,0x30,0x34,0x03,0x36,0x32,0x0D 40 摄氏度
0x02,0xF6,0x30,0x34,0x38,0x30,0x30,0x33,0x30,0x30,0x30,0x46,0x30,0x33,0x03,0x36,0x31,0x0D 39 摄氏度
0x02,0xF6,0x30,0x34,0x38,0x30,0x30,0x33,0x30,0x30,0x30,0x46,0x30,0x32,0x03,0x36,0x30,0x0D 38 摄氏度
0x02,0xF6,0x30,0x34,0x38,0x30,0x30,0x33,0x30,0x30,0x30,0x46,0x30,0x31,0x03,0x35,0x46,0x0D 37 摄氏度
# 带 echo的
0x02,0xF6,0x30,0x34,0x38,0x30,0x30,0x33,0x30,0x32,0x30,0x46,0x30,0x34,0x03,0x36,0x34,0x0D echo -> 40  摄氏度
0x02,0xF6,0x30,0x34,0x38,0x30,0x30,0x33,0x30,0x32,0x30,0x46,0x30,0x33,0x03,0x36,0x33,0x0D echo -> 39  摄氏度
0x02,0xF6,0x30,0x34,0x38,0x30,0x30,0x33,0x30,0x32,0x30,0x46,0x30,0x32,0x03,0x36,0x32,0x0D echo -> 38  摄氏度
# 关闭后,返回的数据
0x02,0xF6,0x30,0x34,0x38,0x30,0x30,0x33,0x30,0x30,0x31,0x31,0x31,0x31,0x03,0x34,0x43,0x0D off
esphome
uart:
  - id: from_master
    baud_rate: 9600
    tx_pin: GPIO16
#    rx_pin: GPIO17
#    debug:
#      direction: BOTH
#      dummy_receiver: true
switch:
  # off
  - platform: template
    optimistic: true
    lambda: "return id(gas_off).state;"
    turn_on_action:
      - uart.write: [0x02,0x55,0x20,0x03,0x37,0x38,0x0D]
    turn_off_action:
    optimistic: true
    lambda: "return id(echo).state;"
    turn_on_action:
      - uart.write: [0x02,0x55,0x29,0x03,0x38,0x31,0x0D]
      - delay: 1s
      - switch.turn_off: echo
    optimistic: true
    lambda: "return id(gas).state;"
    turn_on_action:
      - uart.write: [0x02,0x55,0x30,0x03,0x38,0x38,0x0D]
      - delay: 1s
      - switch.turn_off: gas
    optimistic: true
    lambda: "return id(gas7).state;"
    turn_on_action:
      - uart.write: [0x02,0x55,0x31,0x03,0x38,0x39,0x0D]
      - delay: 1s
      - switch.turn_off: gas7
# 循环发查询命令,保证获取最新的状态。
interval:
  - interval: 900ms
    then:
      - uart.write: [0x02,0xF6,0x30,0x34,0x38,0x30,0x30,0x33,0x03,0x32,0x38,0x0D]
binary_sensor:
  - platform: gpio
    pin: GPIO25
    name: gas heater on/off
    # 物理按键延时抖动消除
    filters:
      - delayed_on: 100ms
      - delayed_off: 100ms
      - delayed_on_off: 100ms
    on_state:
      - delay: 100ms
  - platform: gpio
    pin: GPIO26
    name: gas heater temp +
    filters:
      - delayed_on: 100ms
    on_state:
      - delay: 100ms
  - platform: gpio
    pin: GPIO27
    name: gas heater temp -
    filters:
      - delayed_on: 100ms
    on_state:
      - delay: 100ms
  # not realize
  - platform: gpio
    pin: GPIO21
    name: gas heater eco
    filters:
      - delayed_on: 100ms
    on_state:
      - delay: 100ms
硬件上 要 把 面板上 的 tx 去掉。背面,jp11 的0欧姆电阻拿掉。因为uart只能 1对1 通信。不能同时有2个tx,但可以有2个rx。
现在有个问题,不能使用面版上的按键了。因为 tx 被拿掉了。可能需要找到面版上4个按键对应的io口,然后通过飞线接入esp32
分析按键引脚和 控制芯片之间的关系。
up/down - 12pin adc 根据电压值区分
运行/echo - 14pin adc 根据电压值区分
只需要接2根飞线给esp32 的 adc 口。
请大佬帮忙分析返回码的格式,谢谢。准备写一个外部的组建来读取查询的返回值。
========================================================================================gengxinxinan-======================================
4个按键,每2个,通过 adc 接入控制芯片,分别按下 开机/ eco ,用万用表量了下 输入给控制芯片的电压都差不多,1.045v左右,不知道小日本是通过什么方式判断是不同的按键输入。
猜测可能是通过瞬间峰值电压判断的。因为每个按键都通过一个共阳或共阴二极管接到5v,每个按键处,量的电压相差 0.2v左右。
如果能通过esphome模拟按键输入,就可以不用这么麻烦了。
物理按键接入esp32, 要4根线,需要改电路。原电路是2个按键一起,接入adc,接入esp32,要把他们分开。
按键处理还是有问题,直接接入后,测定电压只有1v左右,不够判定高电平的标准。
完美解决办法,就是重新打板,电路其实非常简单。可能要在esphome里处理下2 位数码管显示问题。
参与人数 1金钱 +5 收起 理由
cym9007 + 5 感谢楼主分享!
发表于 2022-8-11 12:13:52 | 显示全部楼层
我家也是林内热水器,坐等大佬分析。
发表于 2022-8-11 14:07:55 | 显示全部楼层
坐等抄作业,林内的采暖炉,估计一样的吧
发表于 2022-8-11 15:12:15 | 显示全部楼层
坐等抄作业
发表于 2022-8-11 15:21:47 | 显示全部楼层
真的是牛人呀  能率的等一波
发表于 2022-8-11 19:13:40 | 显示全部楼层
calvin886 发表于 2022-8-11 15:21
真的是牛人呀  能率的等一波
hyq
发表于 2022-8-12 08:47:33 | 显示全部楼层
虽然我是能率的,最近也在研究。思路跟大佬一样的!支持大佬!
hyq
发表于 2022-8-12 09:01:44 | 显示全部楼层
大佬我的思路是esphome放在机器跟面板中间,esphome写透传程序,应该不会影响面板使用。无赖我不会代码。如果这样成功了!家里很多小家电都能这样改。期待大佬杰作!
 楼主| 发表于 2022-8-12 19:19:45 | 显示全部楼层
hyq 发表于 2022-8-12 09:01
大佬我的思路是esphome放在机器跟面板中间,esphome写透传程序,应该不会影响面板使用。无赖我不会代码。如 ...
有透传的demo?要是能在uart 之间 串联一个  esphome,那就好办了。不用这么麻烦了。
tink 手机认证
发表于 2022-8-12 21:56:24 来自手机 | 显示全部楼层
ciasdmxhxjjpd@c 发表于 2022-8-12 19:19
有透传的demo?要是能在uart 之间 串联一个  esphome,那就好办了。不用这么麻烦了。 ...
就是收什么发什么就算是变相透传了吧
GMT+8, 2026-1-18 13:50 , Processed in 0.451944 second(s), 15 queries , MemCached On.
