楼主: antsunzj
[经验分享] 11.22更新:告别不断搞坏系统格式化tf之路——给新手的固件
发表于 2018-1-12 14:30:56 | 显示全部楼层
谢谢分享
发表于 2018-1-13 19:28:48 | 显示全部楼层
膜拜大神
发表于 2018-1-17 00:13:39 | 显示全部楼层
謝謝大大滴分享
小白我應該最適合先來玩這個
出問題就直接刪出錯的docker
不需要一直全部重新安裝了
发表于 2018-1-19 15:58:25 | 显示全部楼层
学习!!!!!!!!!!
发表于 2018-1-21 12:49:20 | 显示全部楼层
1、系统启动后报错如何解决,/usr/lib/python3.6这个目录找不到
2、调用command_line也不行,为什么呢?https://bbs.hassbian.com/forum.p ... 510&page=1#pid53973
2018-01-21 12:26:10 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2018-01-21 12:26:10 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
2018-01-21 12:26:28 WARNING (SyncWorker_11) [netdisco.ssdp] Error fetching description at [url]http://169.254.19.109:80/description.xml[/url]
2018-01-21 12:26:28 WARNING (SyncWorker_11) [netdisco.ssdp] Found malformed XML at [url]http://192.168.7.206:9999:[/url] Not Found
2018-01-21 12:37:02 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.6/asyncio/tasks.py", line 179, in _step
    result = coro.send(None)
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 398, in async_process_entity
    new_entity, self, update_before_add=update_before_add
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 239, in async_add_entity
    'Invalid entity id: {}'.format(entity.entity_id))
homeassistant.exceptions.HomeAssistantError: Invalid entity id: light.
2018-01-21 12:42:15 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2018-01-21 12:49:50 ERROR (SyncWorker_7) [homeassistant.components.switch.command_line] Command failed: /usr/bin/python3 /home/homeassistant/.homeassistant/pcPower.py ON 50E54935D58D
2018-01-21 12:49:54 ERROR (SyncWorker_5) [homeassistant.components.switch.command_line] Command failed: /usr/bin/python3 /home/homeassistant/.homeassistant/pcPower.py OFFALL
发表于 2018-1-21 16:20:55 | 显示全部楼层
噶某些分享
发表于 2018-1-21 17:00:30 | 显示全部楼层
谢谢分享
发表于 2018-1-21 18:31:16 | 显示全部楼层
baiduyun下载速度太慢
禁止发言
发表于 2018-1-21 19:20:52 | 显示全部楼层
来试试看看
发表于 2018-1-21 23:37:30 | 显示全部楼层
看看看看
GMT+8, 2026-1-15 18:32 , Processed in 0.912810 second(s), 17 queries , MemCached On.
