查看: 4300|回复: 2
[技术探讨] 搞了个涂鸦智能锁,用涂鸦zigbee网关接入的,怎么接入HA?
ms2 手机认证
发表于 2022-7-24 16:43:45 | 显示全部楼层 |阅读模式
看有人在回帖里说这个涂鸦插件可以接入zigbee子设备:leeyuentuen/localtuya: local handling for Tuya devices (github.com),我看里面的说明也说了支持涂鸦zigbee跟蓝牙的设备,还写了示例代码,有用过的说说,到底行不行呀。
  # Below are examples of configuring devices under a gateway
  # Zigbee or Bluetooth gateway
  - host: 192.168.1.x
    device_id: xxxxxabcd
    local_key: xxxxx
    friendly_name: Tuya Gateway
    protocol_version: "3.3"
    is_gateway: true # This tells it is to be treated as a gateway and skip adding entities
  # Devices under a gateway
  # Other than differences on the device itself (ie. no host and local_key), the rest is the same
  #   as a WiFi device
  - parent_gateway: xxxxabcd # This tells it is a sub-device dependent on a parent gateway
    device_id: xxxx1234 # The cid of sub-device
    friendly_name: Tuya Zigbee Switch
    entities:
      - platform: switch
        friendly_name: Tuya Zigbee Switch Entity 1
      - platform: switch
        friendly_name: Tuya Zigbee Switch Entity 2
    device_id: xxxx5678
    friendly_name: Tuya Zigbee PIR Sensor
    entities:
      - platform: binary_sensor
        friendly_name: Motion Sensor
        device_class: motion
        state_on: pir
        state_off: none
      - platform: sensor
        friendly_name: Sensor Battery
        device_class: battery
发表于 2023-12-10 16:45:17 | 显示全部楼层
请问楼主后来解决了吗?我也在找一个支持Z2M的 锁
ms2 手机认证
 楼主| 发表于 2023-12-23 12:59:10 | 显示全部楼层
没有,搞不定
GMT+8, 2026-1-16 01:34 , Processed in 0.776079 second(s), 7 queries , MemCached On.
