查看: 8088|回复: 16
[求助] 欧普OPPLE智能灯接入失败,貌似不兼容Python3.10?怎么解决...
发表于 2022-7-16 22:28:06 | 显示全部楼层 |阅读模式
前段时间还可以用的,最近更新就不行了。。。
这要怎么解决?是不是只能等官方修复。。
官方文档:https://www.home-assistant.io/integrations/opple
configuration.ymal添加的代码如下:
light:
  - platform: opple
    host: 192.168.2.22
方便的朋友可以测试下,不需要有opple的设备,添加代码,重启hass就会看到错误日志。
错误日志代码如下:
Logger: homeassistant.components.light
Source: components/opple/light.py:63
Integration: 灯光 (documentation, issues)
First occurred: 22:04:12 (1 occurrences)
Last logged: 22:04:12
Error while setting up opple platform for light
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 250, in _async_setup_platform
    await asyncio.shield(task)
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/components/opple/light.py", line 47, in setup_platform
    entity = OppleLight(name, host)
  File "/usr/src/homeassistant/homeassistant/components/opple/light.py", line 63, in __init__
    self._device = OppleLightDevice(host)
  File "/usr/local/lib/python3.10/site-packages/pyoppleio/OppleLightDevice.py", line 12, in __init__
    super().__init__(ip, message)
  File "/usr/local/lib/python3.10/site-packages/pyoppleio/OppleDevice.py", line 30, in __init__
    self.async_init()
  File "/usr/local/lib/python3.10/site-packages/pyoppleio/OppleDevice.py", line 48, in async_init
    message = self.send('SEARCH', reply=True)
  File "/usr/local/lib/python3.10/site-packages/pyoppleio/OppleDevice.py", line 53, in send
    message = Message.build_message(MESSAGE_TYPE[message_type], data, self)
  File "/usr/local/lib/python3.10/site-packages/pyoppleio/Message.py", line 87, in build_message
    message.set_checksum()
  File "/usr/local/lib/python3.10/site-packages/pyoppleio/Message.py", line 33, in set_checksum
    crc = crc16.crc16xmodem(bytes(self.data[0x64:]))
SystemError: PY_SSIZE_T_CLEAN macro must be defined for '#' formats
 楼主| 发表于 2022-7-16 22:30:20 | 显示全部楼层
如果不报错的话,就算没有opple的硬件,也会显示一个“不可用”的实体。
所以大家可以编辑yaml文件测试下~
发表于 2022-7-16 23:09:40 | 显示全部楼层
github 上 ha 项目上 提一个 issue
 楼主| 发表于 2022-7-16 23:22:58 | 显示全部楼层
提了,但是没有一个回复
https://github.com/home-assistant/core/issues/75268
发表于 2022-7-27 23:20:03 | 显示全部楼层
最简单的一个暂时可以使用的方法进入容器删除 /usr/local/lib/python3.10/site-packages/crc16/ 下的_crc16开头的 .so 文件
发表于 2022-7-28 00:02:07 | 显示全部楼层
发表于 2022-7-31 13:09:39 来自手机 | 显示全部楼层
oppo智能灯包含了灯罩么?还是智能灯泡呢。
发表于 2022-7-31 23:01:17 | 显示全部楼层
MARK!!,我最近才刚开始用HASS,添加配置后,一直没识别到我家的欧普吸顶灯。等看看后续解决办法。
发表于 2022-8-1 08:11:16 来自手机 | 显示全部楼层
我添加配置后,倒是可以保存,但就是识别不到我家的欧普灯。
 楼主| 发表于 2022-8-14 12:12:35 | 显示全部楼层
wnstar 发表于 2022-7-27 23:20
最简单的一个暂时可以使用的方法进入容器删除 /usr/local/lib/python3.10/site-packages/crc16/ 下的_crc16 ...
实测可用,感谢大佬!!
暂时先用着了,官方升级了Python3.10后出现不少不兼容的,等修复~
GMT+8, 2025-12-16 17:00 , Processed in 0.107638 second(s), 15 queries , MemCached On.
