查看: 2673|回复: 4
[求助] 远程ESPHOME
发表于 2022-7-15 11:33:38 | 显示全部楼层 |阅读模式
MQTT是不是这样写?路由已映射了1883端口
mqtt:
  broker: http://lrving.xxxx:1883
  username: ox
  password: x123456
  discovery: True
  discovery_retain: true
发表于 2022-7-15 11:50:37 来自手机 | 显示全部楼层
mqtt:
  broker: lrving.xxxx
  username: ox
  password: x123456
 楼主| 发表于 2022-7-15 11:56:28 | 显示全部楼层
tiani 发表于 2022-7-15 11:50
mqtt:
  broker: lrving.xxxx
  username: ox
好的。我测试下。看官网讲好像要关api认证,请问对吗?
 楼主| 发表于 2022-7-15 12:04:09 | 显示全部楼层
1657852288: New connection from 172.30.32.2:39472 on port 1883.
1657852288: Client <unknown> closed its connection.
1657852408: New connection from 172.30.32.2:39474 on port 1883.
1657852408: Client <unknown> closed its connection.
1657852528: New connection from 172.30.32.2:39476 on port 1883.
1657852528: Client <unknown> closed its connection.
1657852648: New connection from 172.30.32.2:39482 on port 1883.
1657852648: Client <unknown> closed its connection.
1657852768: New connection from 172.30.32.2:39484 on port 1883.
1657852768: Client <unknown> closed its connection.
1657852888: New connection from 172.30.32.2:39486 on port 1883.
1657852888: Client <unknown> closed its connection.
1657853008: New connection from 172.30.32.2:39488 on port 1883.
1657853008: Client <unknown> closed its connection.
1657853128: New connection from 172.30.32.2:39490 on port 1883.
1657853128: Client <unknown> closed its connection.
日志。好像不行
 楼主| 发表于 2022-7-15 12:09:36 | 显示全部楼层
mqtt:
  broker: lrving.xxxx
  username: ox
已正常。感谢。
GMT+8, 2025-11-5 10:43 , Processed in 0.956891 second(s), 8 queries , MemCached On.
