查看: 2430|回复: 0
[求助] esphome用uart代码能不能修改读取速度?
发表于 2022-7-14 16:46:11 来自手机 | 显示全部楼层 |阅读模式
现在的串口读取频率太高,每1秒会收到10几条数据变得很不稳定,每两秒就会显示  不可用。可以修改代码来控制读取速率吗?
uart:
- id: uart_bus
  tx_pin:
    number: 1
    mode:
      output: true
      analog: false
      input: false
      open_drain: false
      pullup: false
      pulldown: false
    inverted: false
  rx_pin:
    number: 3
    mode:
      input: true
      analog: false
      output: false
      open_drain: false
      pullup: false
      pulldown: false
    inverted: false
  baud_rate: 115200
  rx_buffer_size: 256
  stop_bits: 1
  data_bits: 8
  parity: NONE
GMT+8, 2025-12-16 15:44 , Processed in 0.960175 second(s), 8 queries , MemCached On.
