查看: 3505|回复: 2
[求助] 关于docker下安装hassio的问题
发表于 2022-7-13 14:22:36 | 显示全部楼层 |阅读模式
按照官网教程到最后一步出现报错,日志如下:
dpkg: error processing archive homeassistant-supervised.deb (--install):
new homeassistant-supervised package pre-installation script subprocess returned error exit status 1
[info] Undo divert on abort-install
No diversion 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised', none removed.
[info] Resetting debconf selections
[info] Removal complete, due to the complexity of this installation method,
[info] you will need to manually remove the containers created by the supervisor
Errors were encountered while processing:
请教如何解决。谢谢!
jjcs 手机认证
发表于 2022-7-13 17:38:31 | 显示全部楼层
提个建议,放弃sup吧
 楼主| 发表于 2022-7-14 16:50:00 | 显示全部楼层
jjcs 发表于 2022-7-13 17:38
提个建议,放弃sup吧
不用supervisor,samba和fileeditor之类不知道咋装
GMT+8, 2025-12-21 10:02 , Processed in 1.008144 second(s), 6 queries , MemCached On.
