查看: 6445|回复: 15
[求助] 升级到最新版的2022.7.3之后和风天气插件报错了
发表于 2022-7-12 13:24:52 | 显示全部楼层 |阅读模式
升级到最新版的2022.7.3之后和风天气插件报错了,不会修改,大佬们有没有帮忙修复一下的?插件地址:https://github.com/shaonianzhentan/hf_weather
shaonianzhentan/hf_weather: 一个不知道改了几手的和风天气最简单的配置版本 (github.com)
Logger: homeassistant.components.weather
Source: custom_components/hf_weather/weather.py:99
Integration: Weather ([color=var(--primary-color)]documentation
, [color=var(--primary-color)]issues
First occurred: 13:09:35 (2 occurrences)
Last logged: 13:11:58
Error while setting up hf_weather platform for weatherTraceback (most recent call last):  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 250, in _async_setup_platform    await asyncio.shield(task)  File "/config/custom_components/hf_weather/weather.py", line 88, in async_setup_entry    async_add_entities([HeFengWeather(data, name)], True)  File "/config/custom_components/hf_weather/weather.py", line 99, in __init__    self._temperature_unit = NoneAttributeError: can't set attribute '_temperature_unit'
3万
发表于 2022-7-12 23:23:24 | 显示全部楼层
修复了一下错误提示:
Home Assistant 2022.7.4 前端版本: 20220707.0 - latest
卡片的单位也修改了一下,但小时预报的单位不能随设置变化,只能固定为°C
hf_weather.zip
86.89 KB, 阅读权限: 20, 下载次数: 44
售价: 1 金钱  [记录]
2022.7.14
发表于 2022-7-12 14:35:13 | 显示全部楼层
/config/custom_components/hf_weather/weather.py 这个文件的99行 : self._temperature_unit  前面加#   注释掉  就好了
 楼主| 发表于 2022-7-12 15:20:23 | 显示全部楼层
貌似不行,改了还是报错,但是错误不一样了
Source: custom_components/hf_weather/weather.py:238
Integration: Weather (documentation, issues)
First occurred: 15:19:12 (1 occurrences)
Last logged: 15:19:12
hf_weather: Error on device update!
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 446, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 702, in async_device_update
    await task
  File "/usr/local/lib/python3.10/asyncio/coroutines.py", line 124, in coro
    res = func(*args, **kw)
  File "/config/custom_components/hf_weather/weather.py", line 238, in async_update
    self._temperature_unit = self._data.temperature_unit
 楼主| 发表于 2022-7-12 15:21:25 | 显示全部楼层
81795791 发表于 2022-7-12 14:35
File "/config/custom_components/hf_weather/weather.py", line 99, in __init__    self._temperature_un ...
    await task
发表于 2022-7-12 15:47:54 | 显示全部楼层
3万
发表于 2022-7-12 16:02:55 | 显示全部楼层
新版温度单位不能在代码中指定了,由天气实体的UI设置中设置,支持多单位自动转换了。
shaonianzhentan/hf_weather 这个修改版不错,卡片引入都集成了。只要修复一下新版的这个单位问题。
 楼主| 发表于 2022-7-12 16:44:22 | 显示全部楼层
shaonianzhentan/hf_ ...
非常感谢,我只是把所有的unit都给屏蔽掉了,可以启动了,但是还有个warning,不影响使用,附件是我简单更改的,仅供大家参考。
Source: components/weather/__init__.py:308
First occurred: 16:37:12 (1 occurrences)
Last logged: 16:37:12
custom_components.hf_weather.weather::HeFengWeather is overriding deprecated methods on an instance of WeatherEntity, this is not valid and will be unsupported from Home Assistant 2023.1. Please report it to the custom component author
weather.zip
3.97 KB, 下载次数: 17
3万
发表于 2022-7-13 00:06:01 | 显示全部楼层
顺便参考这个方法,把彩云天气也做一下卡片集成。安装集成后不需要单独安装卡片,安装简化了不少。
注意:卡片类型名改成了: type: custom:colorfulclouds_weather-card
colorfulclouds.zip
62.27 KB, 阅读权限: 20, 下载次数: 20
售价: 1 金钱  [记录]
2022.7.12
 楼主| 发表于 2022-7-13 09:01:56 | 显示全部楼层
强强强,必须顶一下
GMT+8, 2025-12-17 01:25 , Processed in 0.078296 second(s), 11 queries , MemCached On.
