查看: 2832|回复: 4
[技术探讨] N1上安装 supervised .打不开网页.请问有人能指点不
发表于 2022-7-12 01:26:47 | 显示全部楼层 |阅读模式
root@MyArm:~# dpkg -i homeassistant-supervised.deb
(Reading database ... 65057 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
Leaving 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised'
Leaving 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised'
Leaving 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised'
Leaving 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised'
Unpacking homeassistant-supervised (1.2.1) over (1.2.1) ...
Setting up homeassistant-supervised (1.2.1) ...
[info] Restarting NetworkManager
[info] Restarting docker service
PING version.home-assistant.io (104.26.4.238) 56(84) bytes of data.
64 bytes from 104.26.4.238 (104.26.4.238): icmp_seq=1 ttl=53 time=176 ms
--- version.home-assistant.io ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 175.850/175.850/175.850/0.000 ms
[info] Install supervisor startup scripts
[info] Install AppArmor scripts
[info] Start Home Assistant Supervised
[info] Installing the 'ha' cli
[warn] Could not find /etc/default/grub or /boot/cmdline.txt failed to switch to cgroup v1
[info] Within a few minutes you will be able to reach Home Assistant at:
[info] http://homeassistant.local:8123 or using the IP address of your
[info] machine: http://192.168.123.31:8123
root@MyArm:~# lsb_release -a
No LSB modules are available.
Distributor ID:        Debian
Description:        Debian GNU/Linux 11 (bullseye)
Release:        11
Codename:        bullseye
root@MyArm:~# uname -a
Linux MyArm 5.15.32-arm-64 #22.02.0 SMP PREEMPT Tue Mar 29 13:28:40 CST 2022 aarch64 GNU/Linux
root@MyArm:~#
 楼主| 发表于 2022-7-12 01:33:08 | 显示全部楼层
root@MyArm:~# docker version
Client: Docker Engine - Community
Version:           20.10.17
API version:       1.41
Go version:        go1.17.11
Git commit:        100c701
Built:             Mon Jun  6 23:02:34 2022
OS/Arch:           linux/arm64
Context:           default
Experimental:      true
Server: Docker Engine - Community
Engine:
  Version:          20.10.17
  API version:      1.41 (minimum version 1.12)
  Git commit:       a89b842
  Built:            Mon Jun  6 23:01:01 2022
  Experimental:     false
containerd:
  Version:          1.6.6
  GitCommit:        10c12954828e7c7c9b6e0ea9b0c02b01407d3ae1
runc:
  Version:          1.1.2
  GitCommit:        v1.1.2-0-ga916309
docker-init:
  Version:          0.19.0
  GitCommit:        de40ad0
root@MyArm:~# docker images
REPOSITORY   TAG       IMAGE ID   CREATED   SIZE
DOCKER下.没有镜像的.  能有人指引下吗.那里出错了. .....
N1  用Armbian_22.02.0_Arm-64_bullseye_current_5.15.32.img的镜像.
发表于 2022-7-12 07:25:49 | 显示全部楼层
发表于 2022-7-12 08:31:01 | 显示全部楼层
https://bbs.hassbian.com/thread-17035-1-1.html
是不是跟这个情况一样
发表于 2022-7-16 11:58:50 | 显示全部楼层
是不是跟这个情况一样
我也遇到这个问题,一模一样,重新安装也报错
GMT+8, 2026-1-18 19:48 , Processed in 0.948206 second(s), 13 queries , MemCached On.
