查看: 2615|回复: 1
[求助] Zigbee2mqtt 添加的面板,配对成功后,开关面板打开之后马上....
发表于 2022-7-11 20:42:55 | 显示全部楼层 |阅读模式
配对成功后,一点开的动作,马上又关闭了是为什么呀?
玻璃触模开关面板。
没有通过zigbee2mqtt添加前,正常工作。
 楼主| 发表于 2022-7-13 12:07:29 | 显示全部楼层
报错信息如上
const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
const tz = require('zigbee-herdsman-converters/converters/toZigbee');
const exposes = require('zigbee-herdsman-converters/lib/exposes');
const reporting = require('zigbee-herdsman-converters/lib/reporting');
const extend = require('zigbee-herdsman-converters/lib/extend');
const e = exposes.presets;
const ea = exposes.access;
const definition = {
    zigbeeModel: ['3AFE242000068612'],
    model: 'konke_s2',
    vendor: 'konke',
    description: 'switch2',
    extend: extend.switch(),
    configure: async (device, coordinatorEndpoint, logger) => {
        const endpoint = device.getEndpoint(10);
        await reporting.bind(endpoint, coordinatorEndpoint, ['genOnOff']);
        await reporting.onOff(endpoint)
module.exports = definition;
上面是我的配置文件.js
GMT+8, 2025-12-21 11:56 , Processed in 1.019453 second(s), 7 queries , MemCached On.
