查看: 3899|回复: 2
zigbee2mqtt 启动失败 TypeError: Cannot read properties of null (reading '...
发表于 2022-7-10 22:35:54 | 显示全部楼层 |阅读模式
s6-rc: info: service s6rc-oneshot-runner: startings6-rc: info: service s6rc-oneshot-runner successfully starteds6-rc: info: service fix-attrs: startings6-rc: info: service fix-attrs successfully starteds6-rc: info: service legacy-cont-init: startingcont-init: info: running /etc/cont-init.d/socat.sh[06:26:51] INFO: [color=var(--success-color)]Socat not enabled, marking service as downcont-init: info: /etc/cont-init.d/socat.sh exited 0cont-init: info: running /etc/cont-init.d/zigbee2mqtt.shcont-init: info: /etc/cont-init.d/zigbee2mqtt.sh exited 0s6-rc: info: service legacy-cont-init successfully starteds6-rc: info: service legacy-services: startingservices-up: info: copying legacy longrun socat (no readiness notification)services-up: info: copying legacy longrun zigbee2mqtt (no readiness notification)[06:26:52] INFO: [color=var(--success-color)]Handing over control to Zigbee2MQTT Core ...> [email protected] start> node index.jsZigbee2MQTT:info  2022-07-11 06:26:54: Logging to console and directory: '/config/zigbee2mqtt/log/2022-07-11.06-26-54' filename: log.txtZigbee2MQTT:info  2022-07-11 06:26:54: Starting Zigbee2MQTT version 1.26.0 (commit #unknown)Zigbee2MQTT:info  2022-07-11 06:26:54: Starting zigbee-herdsman (0.14.40)Zigbee2MQTT:error 2022-07-11 06:26:56: Error while starting zigbee-herdsmanZigbee2MQTT:error 2022-07-11 06:26:56: Failed to start zigbeeZigbee2MQTT:error 2022-07-11 06:26:56: Check https://www.zigbee2mqtt.io/guide ... fails-to-start.html for possible solutionsZigbee2MQTT:error 2022-07-11 06:26:56: Exiting...Zigbee2MQTT:error 2022-07-11 06:26:57: TypeError: Cannot read properties of null (reading 'length')    at AdapterNvMemory.init (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-nv-memory.ts:28:42)    at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:60:9)    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:123:29)    at Zigbee.start (/app/lib/zigbee.ts:58:27)    at Controller.start (/app/lib/controller.ts:101:27)    at start (/app/index.js:109:5)[06:26:57] INFO: [color=var(--success-color)]Handing over control to Zigbee2MQTT Core ...> [email protected] start> node index.js
我用的 exsi 7.0 安装的haos淘宝买的zigbee2mqtt 网关 ZHA SONOFF Zigbee 3.0 USB Dongle Plus
为什么报 读取不到长度,
在官网也没有找到原因,
咨询卖家也说不是网关的问题
我也重新安装插件,还是一样的,
我初次安装是可以进入的,现在打开webui 页面502,不能启动,报上面错误,无语了,
 楼主| 发表于 2022-7-12 19:43:51 | 显示全部楼层
有人知道吗?
发表于 2023-12-13 16:54:25 | 显示全部楼层
问题解决了吗
GMT+8, 2026-1-16 01:33 , Processed in 0.461012 second(s), 9 queries , MemCached On.
