查看: 4411|回复: 7
[技术探讨] HA7.1之后WebRTC Camera失效
发表于 2022-7-9 10:34:13 | 显示全部楼层 |阅读模式
问问其他人有发生这种情况吗?摄像头并无问题,app单独看是在工作的。
参照下面方法修复。(https://github.com/AlexxIT/WebRTC/issues/318
  • Change the file custom_components\webrtc\www[webrtc-camera.js]([color=var(--color-accent-fg)]https://raw.githubusercontent.com/skrobul/WebRTC/38c77b400f86f20a42e0b8103bb01f6a0a7377eb/custom_components/webrtc/www/webrtc-camera.js)
  • Delete the .gz file in custom_components\webrtc\www
  • Delete all files in custom_components\webrtc_pycache_
  • If ipban is enabled, disable it
  • If HA is open Browser Tab, close the Tab
  • Clear your browser cache - Change time range to "All time" not only the last hour and
    choose the option "Cached images and files"
  • Open HA App Settings in Android, click to "Stop forced" and delete the cache.
  • Restart HA
  • Open HA in your browser and mobile phone, it should work
  • If ipban was previosly enabled, you can enable again
发表于 2022-7-9 12:17:25 | 显示全部楼层
删除\config\custom_components\webrtc\www路径下的压缩包(具体文件名忘记了),然后清除浏览器和APP缓存试下。
3万
发表于 2022-7-9 12:45:43 来自手机 | 显示全部楼层
我的在7.0后出现这个情况,按https://github.com/AlexxIT/WebRTC/pull/320 操作当时没解决,但升级到7.1后就恢复正常了。7.2还没测试。
3万
3万
我的在7.0后出现这个情况,按https://github.com/AlexxIT/WebRTC/pull/320 操作当时没解决,就没管了,但升级到7.1后就自己恢复正常了。再升7.2也正常。
发表于 2022-7-9 14:23:54 | 显示全部楼层
删除压缩包和更改版本号均无效果
 楼主| 发表于 2022-7-9 19:09:26 | 显示全部楼层
Remove custom_components/webrtc/www/webrtc-camera.js.gz
If you are using HA from the browser, do a hard refresh multiple times (Ctrl+Shift+r on chrome) - instruction for other browsers
If you are using HA client on the android mobile phone, kill/restart the application
if the iOS app, reset the frontend cache. Side bar> app configuration > debugging>reset frontend cache
参照这个步骤没成功
发表于 2022-7-10 00:09:18 | 显示全部楼层
#320
https://github.com/AlexxIT/WebRTC/pull/320/files
67行,自己改下版本号
GMT+8, 2026-1-18 22:02 , Processed in 0.265317 second(s), 11 queries , MemCached On.
