查看: 11888|回复: 18
[基础教程] ha播放小爱音箱的会员歌曲
发表于 2022-7-5 12:01:26 | 显示全部楼层 |阅读模式
   完成思路:    受帖内大佬帖子(小爱音箱+NR+Miot Auto初步实现“自定义跨平台控制” - 『HomeAssistant』综合讨论区 - 『瀚思彼岸』» 智能家居技术论坛 - Powered by Discuz! (hassbian.com))的启发,更新了Xiaomi Miot Auto插件后在小爱音箱集成里多了一个Play Control conversation传感器。这样就可以监控到和小爱的对话,对而进在NR里边写了一个流,对小爱不能播放的绿钻会员歌曲利用云音乐进行播放。
    插曲:我之前的云音乐不能语音控制播放某一首歌,其他功能正常,浏览器conversation也不能播放指定的歌曲,一宿没睡,查论坛、重新安装云音乐、升级ha折腾了一晚上,浏览器conversation服务终于可以正常使用调用播放指定音乐了。
NR实现流程就是:
1:通过Play Control conversation传感器判断与小爱的对话,出现”一分钟试听版“字眼的话,就让小爱暂停播放;
2:把要听的歌曲名字提取出来,形成新的控制语句;
3:传入浏览器conversation,让我的小爱蓝牙音箱播放。
参与人数 1金钱 +1 收起 理由
owbot + 1 感谢楼主分享!
发表于 2022-7-10 22:54:02 | 显示全部楼层
非常不错,NR能否分享一下?
 楼主| 发表于 2022-7-11 15:06:45 | 显示全部楼层
65698888 发表于 2022-7-10 22:54
非常不错,NR能否分享一下?
[{"id":"c6fe8ede158a8f88","type":"tab","label":"小爱音箱会员歌曲用云音乐播放","disabled":false,"info":""},{"id":"b7aa86feed94b601","type":"server-state-changed","z":"c6fe8ede158a8f88","name":"小爱对话","server":"94f0c0a9.629b6","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.xiaomi_lx5a_7d9b_conversation","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":100,"y":300,"wires":[["0d473067753b8248","47c634875cc53d15"]]},{"id":"0d473067753b8248","type":"switch","z":"c6fe8ede158a8f88","name":"判断是否为绿钻歌曲","property":"data.new_state.attributes.answers[0].tts.text","propertyType":"msg","rules":[{"t":"cont","v":"试听版","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":320,"y":220,"wires":[["79720e80049f4dd3","cea722c9573601f2","c5579215fe592fee"],[]]},{"id":"0ffdb07f5f5ce4ad","type":"debug","z":"c6fe8ede158a8f88","name":"1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1210,"y":180,"wires":[]},{"id":"ea3d2c240aa48fb8","type":"debug","z":"c6fe8ede158a8f88","name":"2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":690,"y":560,"wires":[]},{"id":"1693ee29d55c2d1a","type":"api-call-service","z":"c6fe8ede158a8f88","name":"调用conversation云音乐播放","server":"94f0c0a9.629b6","version":5,"debugenabled":false,"domain":"conversation","service":"process","areaId":[],"deviceId":[],"entityId":[],"data":"{\"text\":msg.payload}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1000,"y":160,"wires":[["0ffdb07f5f5ce4ad"]]},{"id":"1e5f80562eaca239","type":"function","z":"c6fe8ede158a8f88","name":"","func":"msg.payload = \"播放歌曲\"+msg.payload[1]\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":790,"y":180,"wires":[["1693ee29d55c2d1a"]]},{"id":"79720e80049f4dd3","type":"split","z":"c6fe8ede158a8f88","name":"","splt":"播放","spltType":"str","arraySplt":"1","arraySpltType":"len","stream":false,"addname":"","x":510,"y":180,"wires":[["591d740644ca4e42"]]},{"id":"591d740644ca4e42","type":"join","z":"c6fe8ede158a8f88","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":650,"y":180,"wires":[["1e5f80562eaca239"]]},{"id":"cea722c9573601f2","type":"delay","z":"c6fe8ede158a8f88","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":540,"y":240,"wires":[["a5ad41115af17cd9"]]},{"id":"a5ad41115af17cd9","type":"xiaoai-mediaplayer","z":"c6fe8ede158a8f88","name":"","xiaoai":"aea8514ac03e7fb4","action":"pause","device":"6d13798f-7cfd-40b8-96ee-a9b300f05a0d","x":770,"y":240,"wires":[[],[]]},{"id":"4f0e1750332d50b3","type":"comment","z":"c6fe8ede158a8f88","name":"小爱音箱会员歌曲用云音乐播放","info":"","x":180,"y":120,"wires":[]},{"id":"47c634875cc53d15","type":"switch","z":"c6fe8ede158a8f88","name":"停止播放","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"休息","vt":"str"},{"t":"cont","v":"暂停","vt":"str"},{"t":"cont","v":"停止","vt":"str"},{"t":"cont","v":"闭嘴","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":280,"y":440,"wires":[["3048db6f3fee4ee5"],["3048db6f3fee4ee5"],["3048db6f3fee4ee5"],["3048db6f3fee4ee5"]]},{"id":"92a4c004e37d1986","type":"api-call-service","z":"c6fe8ede158a8f88","name":"调用conversation云音乐停止","server":"94f0c0a9.629b6","version":5,"debugenabled":false,"domain":"conversation","service":"process","areaId":[],"deviceId":[],"entityId":[],"data":"{\"text\":msg.payload}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":780,"y":440,"wires":[[]]},{"id":"3048db6f3fee4ee5","type":"change","z":"c6fe8ede158a8f88","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"暂停音乐","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":440,"wires":[["92a4c004e37d1986","ea3d2c240aa48fb8"]]},{"id":"c5579215fe592fee","type":"api-call-service","z":"c6fe8ede158a8f88","name":"设置云音乐音量","server":"94f0c0a9.629b6","version":5,"debugenabled":false,"domain":"media_player","service":"volume_set","areaId":[],"deviceId":[],"entityId":["media_player.yun_yin_le"],"data":"{\"volume_level\":\"0.27\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":560,"y":100,"wires":[[]]},{"id":"510465659c5576e7","type":"inject","z":"c6fe8ede158a8f88","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":360,"y":60,"wires":[["c5579215fe592fee"]]},{"id":"94f0c0a9.629b6","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"},{"id":"aea8514ac03e7fb4","type":"xiaoai-tts-configurator","name":""}]
 楼主| 发表于 2022-7-11 15:09:38 | 显示全部楼层
我又增加了语音控制云音乐停止的功能
发表于 2022-7-11 18:39:22 | 显示全部楼层
silas3082 发表于 2022-7-11 15:09
我又增加了语音控制云音乐停止的功能
非常感谢,为什么我的conversation只能输出我说的话,小爱的回答没有输出?
 楼主| 发表于 2022-7-11 21:02:47 | 显示全部楼层
65698888 发表于 2022-7-11 18:39
非常感谢,为什么我的conversation只能输出我说的话,小爱的回答没有输出? ...
debug里输出所有的
发表于 2022-7-11 21:52:34 | 显示全部楼层
silas3082 发表于 2022-7-11 21:02
debug里输出所有的
好像PRO不行,我试了,打印所有都不行。
发表于 2022-10-5 12:44:44 | 显示全部楼层
是不是只会嘟嘟的。。我的网易云不知道为啥也登录不上  显示账号密码错误
发表于 2022-10-6 10:11:35 | 显示全部楼层
大胡子 发表于 2022-10-5 12:44
是不是只会嘟嘟的。。我的网易云不知道为啥也登录不上  显示账号密码错误 ...
我昨天新配置的,tts测试 就听到 嘟嘟嘟 = =
发表于 2022-10-6 19:52:39 | 显示全部楼层
你网易云登录上了嘛
GMT+8, 2026-1-15 18:18 , Processed in 1.612827 second(s), 10 queries , MemCached On.
