查看: 2808|回复: 3
[求助] 图片元素搞的ui界面很耗资源要怎么优化?
发表于 2022-7-5 05:42:34 | 显示全部楼层 |阅读模式
之前用图片元素卡片搞了个页面,发现很耗资源,电脑上还行,但是平板上就吃紧,
安卓平板上装的wall panel 根本就没法用。。用fullykiosk browser还ok,但是一些小动画也是有一点点卡 。包括说操作反应有一点点延迟,比如说开灯的效果没法像电脑上秒开(大概延迟0.5s),然后mac上也会显示“此网页占用大量内存”。我看了下所有的图片文件大小也就5.2MB,所以不知道是不是配置代码的问题。。因为按钮用了很多的mushroom的卡片,还有用一些css动画特效(没有基础不太清楚这个是不是很耗资源)
完整的代码太长了,截取一些常规的配置,懂得大大帮忙看看,不知道还有没有优化的空间。毕竟丝滑还是很重要的。。
type: picture-elements
image: /local/floorplan/303/floorplan.png
elements:
  - type: custom:digital-clock
    dateFormat:
      weekday: long
      day: 2-digit
      month: short
    timeFormat:
      hour: 2-digit
      minute: 2-digit
      hour12: false
    card_mod:
      style: |
        .type-custom-digital-clock {
           font-size: 22px !important;
           font-weight: bold !important;
           color: orange;
        ha-card {
          background-color: transparent;
          box-shadow: none;
    style:
      top: 8%
      left: 88%
      width: 120%
      pointer-events: none
  - type: image
    entity: media_player.sony_bravia_tv
    style:
      top: 50%
      left: 50%
      width: 100%
      mix-blend-mode: lighten
      animation: my-blink 2s linear infinite
    state_image:
      playing: /local/floorplan/303/floorplan_tv.png
      'off': /local/floorplan/303/floorplan000.png
  - type: custom:mushroom-cover-card
    entity: cover.sf_cover_2
    show_position_control: true
    icon: mdi:blinds
    tap_action:
      action: call-service
      service: cover.set_cover_position
      service_data:
        position: 33
      target:
        entity_id: cover.sf_cover_2
    layout: vertical
    primary_info: none
    secondary_info: none
    style:
      top: 30%
      left: 8%
      width: 8%
    card_mod:
      style: |
        ha-card {
          box-shadow: none;
  - type: custom:simple-thermostat
    entity: climate.livingroom
    layout:
      mode:
        names: false
        icons: true
        headings: false
      step: column
    header: false
    control: false
    decimals: '0'
    step_size: '1'
    hide:
      temperature: true
      state: true
    card_mod:
      style: |
        ha-card {
          box-shadow: none;
          --st-font-size-xl: 30px;
          --st-font-size-title: 20px;
          --st-font-size-sensors: 13px;
          --st-spacing: 4px;
    style:
      top: 45%
      left: 48%
      width: 6%
  - type: image
    entity: switch.wall_switch_f238_2
    style:
      top: 50%
      left: 50%
      width: 100%
    state_image:
      'on': /local/floorplan/303/floorplan_cat2.gif
      'off': /local/floorplan/303/floorplan_cat.gif
    state_filter:
      'on': opacity(100%)
      'off': opacity(100%)
  - type: custom:mushroom-fan-card
    entity: fan.xiaomi_fresh_air_ventilator
    hide_state: true
    show_percentage_control: false
    show_oscillate_control: false
    collapsible_controls: false
    icon_animation: true
    fill_container: false
    layout: horizontal
    card_mod:
      style: |
        ha-card {
          box-shadow: none;
    style:
      top: 7%
      left: 56%
  - type: image
    entity: climate.bedroom
    style:
      top: 50%
      left: 50%
      width: 100%
      animation: blink 3s linear infinite
    state_image:
      cool: /local/floorplan/303/floorplan_windws.png
style: |
  ha-card {
    box-shadow: none;
  @keyframes my-blink {
    from {opacity: 50%;}
    to {opacity: 100%;}
    from {opacity: 100%;}
    to {opacity: 50%;}
                @keyframes rotation {
                  0% {
                    transform: rotate(0deg);
                  100% {
                    transform: rotate(360deg);
  @keyframes blink {
    0% {
     opacity: 0;
    50% {
     opacity: 1;
    100% {
     opacity: 0;
发表于 2022-7-5 08:59:49 | 显示全部楼层
这不是Floorplan
直接用网页吧,这个app不好用
发表于 2022-7-5 09:31:45 | 显示全部楼层
动画多了肯定就卡了
 楼主| 发表于 2022-7-5 18:26:04 | 显示全部楼层
602293544 发表于 2022-7-5 08:59
这不是Floorplan
直接用网页吧,这个app不好用
叫这个没啥问题吧。。floorplan本来就是平面图的意思。。
然后,用chrome开网页比用这个fullykiosk browser更卡。。。
GMT+8, 2025-12-22 08:58 , Processed in 0.169475 second(s), 10 queries , MemCached On.
