查看: 3533|回复: 1
[求助] home-assistant.log一直报错
发表于 2017-11-12 18:25:10 | 显示全部楼层 |阅读模式
,貌似是说间歇性的连不上网关,有办法解决吗?问题大吗?我现在有些自动化间歇性的执行不了,会不会和这个问题有关系吗?
2017-11-12 16:13:14 ERROR (SyncWorker_6) [homeassistant.components.light.yeelight] Unable to update bulb status: Bulb closed the connection.
2017-11-12 16:24:15 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d0001a4a474 is taking over 10 seconds
2017-11-12 16:24:15 ERROR (SyncWorker_12) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 16:24:15 ERROR (SyncWorker_12) [PyXiaomiGateway] No data in response from hub None
2017-11-12 16:25:17 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d0001dcb958 is taking over 10 seconds
2017-11-12 16:25:17 ERROR (SyncWorker_8) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 16:25:17 ERROR (SyncWorker_8) [PyXiaomiGateway] No data in response from hub None
2017-11-12 16:27:21 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d0001a4a474 is taking over 10 seconds
2017-11-12 16:27:21 ERROR (SyncWorker_10) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 16:27:21 ERROR (SyncWorker_10) [PyXiaomiGateway] No data in response from hub None
2017-11-12 17:03:25 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d0001a2f614 is taking over 10 seconds
2017-11-12 17:03:25 ERROR (SyncWorker_4) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 17:03:25 ERROR (SyncWorker_4) [PyXiaomiGateway] No data in response from hub None
2017-11-12 17:05:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d00018382a4 is taking over 10 seconds
2017-11-12 17:05:28 ERROR (SyncWorker_3) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 17:05:28 ERROR (SyncWorker_3) [PyXiaomiGateway] No data in response from hub None
2017-11-12 17:10:37 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d0001a4a474 is taking over 10 seconds
2017-11-12 17:10:37 ERROR (SyncWorker_8) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 17:10:37 ERROR (SyncWorker_8) [PyXiaomiGateway] No data in response from hub None
2017-11-12 17:19:54 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.motion_sensor_158d0001d58c50 is taking over 10 seconds
2017-11-12 17:19:54 ERROR (SyncWorker_1) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 17:19:54 ERROR (SyncWorker_1) [PyXiaomiGateway] No data in response from hub None
2017-11-12 17:26:37 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d0001a2f614 is taking over 10 seconds
2017-11-12 17:26:37 ERROR (SyncWorker_6) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 17:26:37 ERROR (SyncWorker_6) [PyXiaomiGateway] No data in response from hub None
2017-11-12 17:27:39 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d00018382a4 is taking over 10 seconds
2017-11-12 17:27:39 ERROR (SyncWorker_17) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 17:27:39 ERROR (SyncWorker_17) [PyXiaomiGateway] No data in response from hub None
2017-11-12 17:28:10 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d00018382a4 is taking over 10 seconds
2017-11-12 17:28:10 ERROR (SyncWorker_9) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 17:28:10 ERROR (SyncWorker_9) [PyXiaomiGateway] No data in response from hub None
2017-11-12 17:38:57 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d00018382a4 is taking over 10 seconds
2017-11-12 17:38:57 ERROR (SyncWorker_1) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 17:38:57 ERROR (SyncWorker_1) [PyXiaomiGateway] No data in response from hub None
2017-11-12 17:39:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.motion_sensor_158d000163e325 is taking over 10 seconds
2017-11-12 17:39:28 ERROR (SyncWorker_8) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 17:39:28 ERROR (SyncWorker_8) [PyXiaomiGateway] No data in response from hub None
2017-11-12 17:44:45 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-11-12 17:48:19 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-11-12 17:49:13 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d00018382a4 is taking over 10 seconds
2017-11-12 17:49:13 ERROR (SyncWorker_0) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 17:49:13 ERROR (SyncWorker_0) [PyXiaomiGateway] No data in response from hub None
2017-11-12 17:52:19 ERROR (SyncWorker_0) [homeassistant.components.light.yeelight] Unable to turn the bulb off: A socket error occurred when sending the command.
2017-11-12 17:59:31 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d0001a4a474 is taking over 10 seconds
2017-11-12 17:59:31 ERROR (SyncWorker_15) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 17:59:31 ERROR (SyncWorker_15) [PyXiaomiGateway] No data in response from hub None
2017-11-12 18:05:58 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-11-12 18:06:12 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d0001a2f614 is taking over 10 seconds
2017-11-12 18:06:12 ERROR (SyncWorker_10) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 18:06:12 ERROR (SyncWorker_10) [PyXiaomiGateway] No data in response from hub None
2017-11-12 18:06:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d00018382a4 is taking over 10 seconds
2017-11-12 18:06:43 ERROR (SyncWorker_14) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 18:06:43 ERROR (SyncWorker_14) [PyXiaomiGateway] No data in response from hub None
2017-11-12 18:08:16 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d0001a4a474 is taking over 10 seconds
2017-11-12 18:08:16 ERROR (SyncWorker_18) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 18:08:16 ERROR (SyncWorker_18) [PyXiaomiGateway] No data in response from hub None
2017-11-12 18:13:24 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-11-12 18:15:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d0001a2f614 is taking over 10 seconds
2017-11-12 18:15:28 ERROR (SyncWorker_11) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 18:15:28 ERROR (SyncWorker_11) [PyXiaomiGateway] No data in response from hub None
2017-11-12 18:15:39 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.door_window_sensor_158d0001a4a474 is taking over 10 seconds
2017-11-12 18:15:39 ERROR (SyncWorker_18) [PyXiaomiGateway] Cannot connect to Gateway
2017-11-12 18:15:39 ERROR (SyncWorker_18) [PyXiaomiGateway] No data in response from hub None
发表于 2017-11-12 18:29:46 | 显示全部楼层
把网关ip设为固定的试试,另外试着调调无线参数,如信道什么的,可能会影响连接。
GMT+8, 2025-12-25 15:40 , Processed in 0.751782 second(s), 11 queries , MemCached On.
